Aussie 914 Restoration |
barrym |
Oct 26 2014, 04:05 PM
Member Group: Members Posts: 88 Joined: 12-October 14 From: Australia Member No.: 18,008 Region Association: None |
First time post of lurking here for a while.
I bought a '75 914 a couple of weeks ago that had already been partly pulled apart to restore- its mostly complete but needs to be further pulled down to repair the rust & make mods to it for my intended purpose. it already came as right hand drive and has an amazingly good condition dash board. I have no history with the car so cant tell who or when the conversion was done. I don't even know if it was a US or European import, or if it was an aussie delivered car ... how can I tell ??? it has a scallop out of the right hand side chassis rail for the handbrake, but not the left hand side ... it used to be viper green and has had a poor respray in red - it's going back to viper green (IMG:style_emoticons/default/smile.gif) I have some garage space with a couple of chaps who has worked on 14's before which is a HUGE help to me, very lucky as i'm new to Porsche having owned lotus's for years (and still do). the plan is to restore it for partial road use but mostly track & tarmac rally. in the short term I plan to drop a 3.0 Subaru engine in while I build up funds & parts for a 2.7 Porsche engine. Its been in dry storage for at least 11 years than I know of, and possibly more before that. anyway, am documenting my rebuild thread here. I've made a start on removing the hacked up loom & vacuuming all the loose rust out. Its better than expected (as I bought the car only from pictures) it needs; new hell holes back of floorpan & bottom of firewall boot and that's about it - the rest of it looks (at this stage) like only surface rust - the suspension consoles are solid as is the majority of the front boot - again, only surface rust there ... the windscreen will come out next to get access to pull out the dash so I can continue to remove the loom. i'll be making up a new loom for it. question though - how do I remove the left hand seat ? the lever at the side does nothing - possibly broken ? and there is no handle at the front to slide the seat forwards to get at the rear bolts ... stumped on this one ... Attached image(s) |
barrym |
Jan 20 2016, 03:59 PM
managed to get a few things done over the xmas break ...
the RCI fuel tank was delivered and I mocked up the mounting position for it so I could make up the brackets for the radiator (celica gts rad) - this was an interesting process, the tabs at the bottom have about a 10 degree twist in them as well as being angled, will take some pics when they are welded in place. also, what took AGES was the shifter linkage - using a lotus elise shifter tunnel & cables I measured, then measured more, then mocked up, then tore apart, then mocked up again and finally completed it ... it works perfectly ! as you can see from the pic, I also modified the gearbox for 2wd & made a rear plate. I do already have a gearbox that I did the 2wd mod on, its a slightly older box tho and theres no harm in keeping a spare (IMG:style_emoticons/default/smile.gif) you can see the bottom of the L shaped part is the pivot point, this has a sealed ball bearing in there for nice free movement - I made the cap for it by using a hydraulic hole cutter, but inverting the cutter part, using it as a press to shape a piece of metal to cover the flange in the bearing and keeping it in place. (pic of the press attached) it works extremely well - the other idea was to use a bearing flange, as per the 3rd pic, which I still have as an option if this doesn't work out ... I obviously also have had good use of out the zinc plating kit (IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:38 AM |
