Aussie 914 Restoration |
barrym |
Oct 26 2014, 04:05 PM
Member Group: Members Posts: 88 Joined: 12-October 14 From: Australia Member No.: 18,008 Region Association: None |
First time post of lurking here for a while.
I bought a '75 914 a couple of weeks ago that had already been partly pulled apart to restore- its mostly complete but needs to be further pulled down to repair the rust & make mods to it for my intended purpose. it already came as right hand drive and has an amazingly good condition dash board. I have no history with the car so cant tell who or when the conversion was done. I don't even know if it was a US or European import, or if it was an aussie delivered car ... how can I tell ??? it has a scallop out of the right hand side chassis rail for the handbrake, but not the left hand side ... it used to be viper green and has had a poor respray in red - it's going back to viper green (IMG:style_emoticons/default/smile.gif) I have some garage space with a couple of chaps who has worked on 14's before which is a HUGE help to me, very lucky as i'm new to Porsche having owned lotus's for years (and still do). the plan is to restore it for partial road use but mostly track & tarmac rally. in the short term I plan to drop a 3.0 Subaru engine in while I build up funds & parts for a 2.7 Porsche engine. Its been in dry storage for at least 11 years than I know of, and possibly more before that. anyway, am documenting my rebuild thread here. I've made a start on removing the hacked up loom & vacuuming all the loose rust out. Its better than expected (as I bought the car only from pictures) it needs; new hell holes back of floorpan & bottom of firewall boot and that's about it - the rest of it looks (at this stage) like only surface rust - the suspension consoles are solid as is the majority of the front boot - again, only surface rust there ... the windscreen will come out next to get access to pull out the dash so I can continue to remove the loom. i'll be making up a new loom for it. question though - how do I remove the left hand seat ? the lever at the side does nothing - possibly broken ? and there is no handle at the front to slide the seat forwards to get at the rear bolts ... stumped on this one ... Attached image(s) |
barrym |
May 9 2016, 08:28 PM
have been making some solid progress over the last few weeks ...
took a cut off wheel to the pedal box area & made up a new box for the 3 pedal assembly - its not completely done, but I have an off road adventure through western Australia to go on soon so just covered it up in primer while i'm away. the new pedal assembly had to be cut up a bit and I had to make up a new accelerator pedal & associated brackets / levers for the cable - took a day, well, 8am to 3pm to sort out the pedal ratio's & brackets etc ... the new pedal doesn't have the capability for a brake bias adjuster cable to run through it - the old one had a big U shape in the pedal to accommodate it. instead i'll use a 90 degree gearbox on the end of the bias bar. i'm using wildwood master cylinders, of the 'compact' variety - they give me about an inch of clearance from the steering arm flexi joint. I still have to work on the cross bar strap, but have a cunning plan that will leave it in place and provide some additional rigidity to the pedal box area. had to get the shell on the rotisserie in order to do all this too ... (IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 06:20 AM |
