Aussie 914 Restoration |
barrym |
Oct 26 2014, 04:05 PM
Member Group: Members Posts: 88 Joined: 12-October 14 From: Australia Member No.: 18,008 Region Association: None |
First time post of lurking here for a while.
I bought a '75 914 a couple of weeks ago that had already been partly pulled apart to restore- its mostly complete but needs to be further pulled down to repair the rust & make mods to it for my intended purpose. it already came as right hand drive and has an amazingly good condition dash board. I have no history with the car so cant tell who or when the conversion was done. I don't even know if it was a US or European import, or if it was an aussie delivered car ... how can I tell ??? it has a scallop out of the right hand side chassis rail for the handbrake, but not the left hand side ... it used to be viper green and has had a poor respray in red - it's going back to viper green (IMG:style_emoticons/default/smile.gif) I have some garage space with a couple of chaps who has worked on 14's before which is a HUGE help to me, very lucky as i'm new to Porsche having owned lotus's for years (and still do). the plan is to restore it for partial road use but mostly track & tarmac rally. in the short term I plan to drop a 3.0 Subaru engine in while I build up funds & parts for a 2.7 Porsche engine. Its been in dry storage for at least 11 years than I know of, and possibly more before that. anyway, am documenting my rebuild thread here. I've made a start on removing the hacked up loom & vacuuming all the loose rust out. Its better than expected (as I bought the car only from pictures) it needs; new hell holes back of floorpan & bottom of firewall boot and that's about it - the rest of it looks (at this stage) like only surface rust - the suspension consoles are solid as is the majority of the front boot - again, only surface rust there ... the windscreen will come out next to get access to pull out the dash so I can continue to remove the loom. i'll be making up a new loom for it. question though - how do I remove the left hand seat ? the lever at the side does nothing - possibly broken ? and there is no handle at the front to slide the seat forwards to get at the rear bolts ... stumped on this one ... Attached image(s) |
barrym |
Aug 24 2016, 01:39 AM
wow - time really does fly - looking at some of the pics above and where i'm at now it doesn't feel like I've achieved as much as I should - but I've been working a lot on the detail bits.
I was scratching my head over the way to bolt in the rearward facing stay from the front suspension cross bar given I cut out the pedal box area - I saw a few options but settled on welding in some re-enforcement and welding in a cross bar with out of 5mm bar & welded in a new mounting tab - fits perfectly and clears the 3 master cylinders that poke through the pedal box. the MC's also clear the steering rack when its installed. the top of the pedal box (the angled part) also now has holes cut in it for the brake fluid bottle. I did the relevant cuts and installed a front sway bar, also using the maddog reinforcement plates in the wheel arches. I made up a battery tray, & bolted it in place - its painted with an epoxy paint in pewter - i'll be painting the interior of the car in this colour. All the fuel lines are now cut to length & bulkhead mounts installed. didn't realise the RCI fuel tank came with a built in roll over valve - handy that ! i'm still waiting on a few AN6 hose ends to arrive, but all that's left to do is to a final fit of the lines when i'm ready. I've also finished all the fuel line routing on the engine - I've scrapped most of the factory fueling system and ensured parallel fueling is feeding both rails properly with a rising rate fuel pressure reg. I picked up a stainless manifold that was on sale - $180AUD ! wrapped it in tape - doent need to last a long time as i'll get it ceramic coated in the future at some point ... Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:38 AM |
