CV removal, PITA screw heads stripped |
DavidSweden |
Oct 27 2014, 02:52 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am doing a 5 lug conversion and have hit a problem.
I started to remove the CV joint from the transmission flange in order to remove the half shaft and stub axle. Unfortunately 2 of the pan head screws that hold the CV joint to the transmission flange have stripped so that the tool (allen key) just rotates in the screw head. Anyone got an effective way to get these screws out? Thanks |
914Sixer |
Oct 27 2014, 03:09 PM
Large vise grips.
GaroldShaffer |
Oct 27 2014, 03:15 PM
Large vise grips. (IMG:style_emoticons/default/agree.gif) Also they shouldn't be allen key, you need a triple square bit. Attached image(s) |
Oct 27 2014, 03:41 PM
Large vise grips. (IMG:style_emoticons/default/agree.gif) Also they shouldn't be allen key, you need a triple square bit. (IMG:style_emoticons/default/agree.gif) I got one at my flaps for a couple dollars but tangerine racing sells one that looks nice. |
JawjaPorsche |
Oct 27 2014, 04:17 PM
Large vise grips. (IMG:style_emoticons/default/agree.gif) Also they shouldn't be allen key, you need a triple square bit. (IMG:style_emoticons/default/agree.gif) I got one at my flaps for a couple dollars but tangerine racing sells one that looks nice. Got my socket from Tangerine Racing. Good Quality. http://www.tangerineracing.com/transmission.htm TC's Garage has new bolts: http://www.tcsgarage.com/store/N0147152...LT+914+12-point You need to use NEW schorr washers. http://www.tcsgarage.com/store/99952310301...ED+FOR+CV+BOLTS |
DavidSweden |
Oct 27 2014, 04:28 PM
Thanks for the feedback. I thought the screws were allen that probably explains why the heads stripped.
Live and learn |
rjames |
Oct 27 2014, 04:35 PM
I'm made of metal Group: Members Posts: 3,932 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Thanks for the feedback. I thought the screws were allen that probably explains why the heads stripped. Live and learn You won't be the first, and the right tool might still allow you to remove them. Vice grips will work, too. (IMG:style_emoticons/default/smile.gif) You can convert to bolts with allen heads if you wish. There is at least one vendor here selling them. |
altitude411 |
Oct 27 2014, 04:49 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
Also, make sure you clean the heads out very well and lightly tap the spline tool into the head before wrenchin on 'em.
Cap'n Krusty |
Oct 27 2014, 04:59 PM
Large vise grips. (IMG:style_emoticons/default/agree.gif) Also they shouldn't be allen key, you need a triple square bit. I'm gonna give you a one-time Krustypass, Garold. For once and for all (like I really believe that!), early cars came with 6mm Allen head CV joint bolts. Nothing anybody parrots here is gonna go back and change that. There are STILL cars out there with those bolts, like it or not. Large Vise Grips or channel lock pliers won't fit in there, either ... If the bolts that stripped are truly 6mm Allen socket head hardware, driving a good quality 8mm triple square tool will often be enough to remove the damaged bolt. Always clean out the cavity BEFORE inserting the tool. If that won't do it, then you need a pair of 10" (I think) curved jaw channel locks. I guarantee they'll do the job, as others here can attest. The Cap'n |
bdstone914 |
Oct 27 2014, 06:53 PM
bdstone914 Group: Members Posts: 4,521 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If you do have actual 6mm Allen head bolts and have stripped them you way be able to get a 1/4 inch Allen wrench in there as it is a few thousands larger.
Very important to get the wrench in all the way to the bottom. Tap in in with a hammer. |
GaroldShaffer |
Oct 27 2014, 08:26 PM
Large vise grips. (IMG:style_emoticons/default/agree.gif) Also they shouldn't be allen key, you need a triple square bit. I'm gonna give you a one-time Krustypass, Garold. For once and for all (like I really believe that!), early cars came with 6mm Allen head CV joint bolts. Nothing anybody parrots here is gonna go back and change that. There are STILL cars out there with those bolts, like it or not. Large Vise Grips or channel lock pliers won't fit in there, either ... Fine Crusty I bow to your greatness (IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/biggrin.gif) But I will argue all day long that you can use vise grips to remove the bolts at the transmission flange. |
Oct 27 2014, 08:30 PM
When you are really screwed, go to the cheap tool store and buy a set of Torx bits and hammer one in there, that will get it out.
The torx bit could be ruined after this, so don't buy a nice one. |
914itis |
Oct 27 2014, 10:22 PM
Large vise grips. (IMG:style_emoticons/default/agree.gif) Also they shouldn't be allen key, you need a triple square bit. I'm gonna give you a one-time Krustypass, Garold. For once and for all (like I really believe that!), early cars came with 6mm Allen head CV joint bolts. Nothing anybody parrots here is gonna go back and change that. There are STILL cars out there with those bolts, like it or not. Large Vise Grips or channel lock pliers won't fit in there, either ... Fine Crusty I bow to your greatness (IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/biggrin.gif) But I will argue all day long that you can use vise grips to remove the bolts at the transmission flange. I have |
Cap'n Krusty |
Oct 27 2014, 11:19 PM
THIS is the tool that works:
Quick and dirty. Channel Lock NutbusterĀ® Tongue and Groove Plier, 9-1/2" The Cap'n |
ThePaintedMan |
Oct 28 2014, 06:33 AM
THIS is the tool that works: Quick and dirty. Channel Lock NutbusterĀ® Tongue and Groove Plier, 9-1/2" The Cap'n (IMG:style_emoticons/default/agree.gif) I haven't had to resort to that yet, but if the bolts were torqued correctly, they're only held on with 33 ft/lbs. A good pair of channel locks should be the trick. No matter how old the bolts are, every time I remove them though I always do as others suggested and clean out the inside of the bolt head both with a pick and then with brake cleaner to get full engagement of the triple square socket. |
altitude411 |
Oct 28 2014, 08:46 AM
DavidSweden |
Oct 28 2014, 11:23 AM
Tried the torx didnt work guess I stripped them too much.
I cut the heads of with a small angle grinder. CVs now removed thanks for taking the time to help |
pilothyer |
Oct 28 2014, 12:34 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Sounds like you doubled your pleasure, cut the heads off, then use vice grips to remove the remains. (IMG:style_emoticons/default/biggrin.gif)
Mark Henry |
Oct 28 2014, 04:48 PM
If the tranny was out you can undo the big hub nut and pull everything out in one shot.
Lo-Fi Version | Time is now: 15th May 2024 - 05:23 PM |
