QUOTE(Garold Shaffer @ Oct 27 2014, 02:15 PM)
QUOTE(914Sixer @ Oct 27 2014, 04:09 PM)
Large vise grips.
Also they shouldn't be allen key, you need a triple square bit.
I'm gonna give you a one-time Krustypass, Garold. For once and for all (like I really believe that!), early cars came with 6mm Allen head CV joint bolts. Nothing anybody parrots here is gonna go back and change that. There are STILL cars out there with those bolts, like it or not. Large Vise Grips or channel lock pliers won't fit in there, either ...
If the bolts that stripped are truly 6mm Allen socket head hardware, driving a good quality 8mm triple square tool will often be enough to remove the damaged bolt. Always clean out the cavity BEFORE inserting the tool. If that won't do it, then you need a pair of 10" (I think) curved jaw channel locks. I guarantee they'll do the job, as others here can attest.
The Cap'n
