Is this 1.7 engine code, WA |
ndfrigi |
Oct 28 2014, 05:19 PM
Advanced Member Group: Members Posts: 2,928 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
ndfrigi |
Oct 28 2014, 05:21 PM
G e o r g e |
Oct 28 2014, 05:38 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
no
look here for info (IMG:style_emoticons/default/type.gif) 914 info on top of page (IMG:style_emoticons/default/drunk.gif) |
ndfrigi |
Oct 28 2014, 07:39 PM
no look here for info (IMG:style_emoticons/default/type.gif) 914 info on top of page (IMG:style_emoticons/default/drunk.gif) Thanks! And yes I did search on that engine info on this site. But it says W is the code for 1971 1.7 but the engine I have not only has W but "WA" where the common 1.7 and 1.8 engine numbers located and below the oil filler neck with numbers I believe are all 2.0 or GC/GA numbers. That is why I'm a little bit confuse on this engine I got. Currently it has tail shifter engine support bar on it. thanks again! |
7TPorsh |
Oct 29 2014, 11:37 AM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
no look here for info (IMG:style_emoticons/default/type.gif) 914 info on top of page (IMG:style_emoticons/default/drunk.gif) Thanks! And yes I did search on that engine info on this site. But it says W is the code for 1971 1.7 but the engine I have not only has W but "WA" where the common 1.7 and 1.8 engine numbers located and below the oil filler neck with numbers I believe are all 2.0 or GC/GA numbers. That is why I'm a little bit confuse on this engine I got. Currently it has tail shifter engine support bar on it. thanks again! The 1.7 W blocks were tagged at the back of the case near the tranny hookup...looks like that's where your W is...but I don't see a number in there. |
ndfrigi |
Oct 29 2014, 12:13 PM
no look here for info (IMG:style_emoticons/default/type.gif) 914 info on top of page (IMG:style_emoticons/default/drunk.gif) Thanks! And yes I did search on that engine info on this site. But it says W is the code for 1971 1.7 but the engine I have not only has W but "WA" where the common 1.7 and 1.8 engine numbers located and below the oil filler neck with numbers I believe are all 2.0 or GC/GA numbers. That is why I'm a little bit confuse on this engine I got. Currently it has tail shifter engine support bar on it. thanks again! The 1.7 W blocks were tagged at the back of the case near the tranny hookup...looks like that's where your W is...but I don't see a number in there. Yes only WA and the number below the oil filler looks like it was tagged in there on top of a numbers underneath. I tried to pull the left side of the tag and I saw Letter "C J" before some numbers but can't get those numbers because of the riveted tag. Well google shows it was "1976-1979 2000cc - European Only". Do you think it was for a combination of 914 and Type 2 engine combine? The engine bar underneath was for a 914 transmission tail shifter. thanks for your response! |
pilothyer |
Oct 29 2014, 12:37 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
ndfrigi |
Oct 29 2014, 02:30 PM
Cap'n Krusty |
Oct 29 2014, 03:15 PM
Those are smog pump heads, making it either a 1.7 bus motor or a 2.0 914 motor. Are there block off plated below #1 on the case and behind/above the taco plate? It has a 914 dipstick location, which "could" mean it's a 2 liter 914.
The Cap'n |
Jake Raby |
Oct 30 2014, 02:39 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Those are smog pump heads, making it either a 1.7 bus motor or a 2.0 914 motor. Are there block off plated below #1 on the case and behind/above the taco plate? It has a 914 dipstick location, which "could" mean it's a 2 liter 914. The Cap'n Or it came from a 412, which had a dipstick and an oil fill tube provision.. If so the area at the bottom where the oil fill tube went would be blocked off. Look between the blower housing and the crankcase greater (in the valley) for a number, too. |
ndfrigi |
Oct 30 2014, 04:25 PM
Those are smog pump heads, making it either a 1.7 bus motor or a 2.0 914 motor. Are there block off plated below #1 on the case and behind/above the taco plate? It has a 914 dipstick location, which "could" mean it's a 2 liter 914. The Cap'n Or it came from a 412, which had a dipstick and an oil fill tube provision.. If so the area at the bottom where the oil fill tube went would be blocked off. Look between the blower housing and the crankcase greater (in the valley) for a number, too. Thanks for your input "The Cap'n" and to you Jake Raby! It looks like it came from 412/411 and the CJ beginning engine code at the bottom of the oil filler I think is from Type 2 engine. Maybe the previous owner made some collection of various VW engine parts and installed 914 tins on it. Well I hope someone from 914world would be interested using this for a core or temporary engine while building their engine. I may not be able to use this for my teens. Thanks again and God Bless! |
Lo-Fi Version | Time is now: 27th April 2024 - 04:24 AM |
