Is this 1.7 engine code, WA |
ndfrigi |
Oct 28 2014, 05:19 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
G e o r g e |
Oct 28 2014, 05:38 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
no
look here for info (IMG:style_emoticons/default/type.gif) 914 info on top of page (IMG:style_emoticons/default/drunk.gif) |
ndfrigi |
Oct 28 2014, 07:39 PM
no look here for info (IMG:style_emoticons/default/type.gif) 914 info on top of page (IMG:style_emoticons/default/drunk.gif) Thanks! And yes I did search on that engine info on this site. But it says W is the code for 1971 1.7 but the engine I have not only has W but "WA" where the common 1.7 and 1.8 engine numbers located and below the oil filler neck with numbers I believe are all 2.0 or GC/GA numbers. That is why I'm a little bit confuse on this engine I got. Currently it has tail shifter engine support bar on it. thanks again! |
7TPorsh |
Oct 29 2014, 11:37 AM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
no look here for info (IMG:style_emoticons/default/type.gif) 914 info on top of page (IMG:style_emoticons/default/drunk.gif) Thanks! And yes I did search on that engine info on this site. But it says W is the code for 1971 1.7 but the engine I have not only has W but "WA" where the common 1.7 and 1.8 engine numbers located and below the oil filler neck with numbers I believe are all 2.0 or GC/GA numbers. That is why I'm a little bit confuse on this engine I got. Currently it has tail shifter engine support bar on it. thanks again! The 1.7 W blocks were tagged at the back of the case near the tranny hookup...looks like that's where your W is...but I don't see a number in there. |
ndfrigi |
Oct 29 2014, 12:13 PM
no look here for info (IMG:style_emoticons/default/type.gif) 914 info on top of page (IMG:style_emoticons/default/drunk.gif) Thanks! And yes I did search on that engine info on this site. But it says W is the code for 1971 1.7 but the engine I have not only has W but "WA" where the common 1.7 and 1.8 engine numbers located and below the oil filler neck with numbers I believe are all 2.0 or GC/GA numbers. That is why I'm a little bit confuse on this engine I got. Currently it has tail shifter engine support bar on it. thanks again! The 1.7 W blocks were tagged at the back of the case near the tranny hookup...looks like that's where your W is...but I don't see a number in there. Yes only WA and the number below the oil filler looks like it was tagged in there on top of a numbers underneath. I tried to pull the left side of the tag and I saw Letter "C J" before some numbers but can't get those numbers because of the riveted tag. Well google shows it was "1976-1979 2000cc - European Only". Do you think it was for a combination of 914 and Type 2 engine combine? The engine bar underneath was for a 914 transmission tail shifter. thanks for your response! |
Lo-Fi Version | Time is now: 31st May 2024 - 11:28 AM |
