Is this 1.7 engine code, WA |
ndfrigi |
Oct 28 2014, 05:19 PM
Advanced Member Group: Members Posts: 2,928 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Cap'n Krusty |
Oct 29 2014, 03:15 PM
Those are smog pump heads, making it either a 1.7 bus motor or a 2.0 914 motor. Are there block off plated below #1 on the case and behind/above the taco plate? It has a 914 dipstick location, which "could" mean it's a 2 liter 914.
The Cap'n |
Jake Raby |
Oct 30 2014, 02:39 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Those are smog pump heads, making it either a 1.7 bus motor or a 2.0 914 motor. Are there block off plated below #1 on the case and behind/above the taco plate? It has a 914 dipstick location, which "could" mean it's a 2 liter 914. The Cap'n Or it came from a 412, which had a dipstick and an oil fill tube provision.. If so the area at the bottom where the oil fill tube went would be blocked off. Look between the blower housing and the crankcase greater (in the valley) for a number, too. |
ndfrigi |
Oct 30 2014, 04:25 PM
Those are smog pump heads, making it either a 1.7 bus motor or a 2.0 914 motor. Are there block off plated below #1 on the case and behind/above the taco plate? It has a 914 dipstick location, which "could" mean it's a 2 liter 914. The Cap'n Or it came from a 412, which had a dipstick and an oil fill tube provision.. If so the area at the bottom where the oil fill tube went would be blocked off. Look between the blower housing and the crankcase greater (in the valley) for a number, too. Thanks for your input "The Cap'n" and to you Jake Raby! It looks like it came from 412/411 and the CJ beginning engine code at the bottom of the oil filler I think is from Type 2 engine. Maybe the previous owner made some collection of various VW engine parts and installed 914 tins on it. Well I hope someone from 914world would be interested using this for a core or temporary engine while building their engine. I may not be able to use this for my teens. Thanks again and God Bless! |
Lo-Fi Version | Time is now: 8th May 2024 - 08:13 PM |
