How to Get Engine onto Engine Stand? |
VWTortuga336 |
Oct 29 2014, 08:16 AM
Member Group: Members Posts: 285 Joined: 5-October 14 From: Kansas City, Missouri Member No.: 17,979 Region Association: None |
This may have already been covered, but I haven't had any luck figuring my problem out. I've got my engine pulled, tranny separated and the engine is on my ATV jack. I just bought an engine stand and now I can't figure out how to mount the engine to it (IMG:style_emoticons/default/headbang.gif) The ATV jack won't raise high enough to get all 4 mounting points to line up. And, the base of the stand won't allow the stand to get close enough to the engine, due to the base of the jack.
Anyone have any tricks they could share? Attached thumbnail(s) |
r_towle |
Oct 29 2014, 08:31 AM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Seeing as you have a three wheel engine stand, you could raise and block the motor, then raise and block the jack, leaving a hole in the middle for the engine stand leg.
Keep doing that until it's at the right height to allow you to slide the engine stand under the jack, right up the the motor. Remove the heat exchangers Turn the motor sideways on that lift to avoid the handle. |
Lo-Fi Version | Time is now: 22nd May 2024 - 04:40 PM |
