Tail shifter leak, so I fixed it. |
eyesright |
Oct 29 2014, 06:22 PM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
I bought this -6 conversion project on Ebay too many years ago. It finally got off jackstands and I filled the transmission with GL-5. The next morning I found a good sized puddle under the shift rod. It wasn't the first "au krappe" moment for this project.
So I drained the oil. I would like to have saved it but it was getting too complicated... |
eyesright |
Oct 29 2014, 06:26 PM
eyesright |
Oct 29 2014, 06:32 PM
eyesright |
Oct 29 2014, 06:45 PM
eyesright |
Oct 29 2014, 06:48 PM
eyesright |
Oct 29 2014, 06:55 PM
eyesright |
Oct 29 2014, 07:01 PM
I tightened up the header and added fresh GL-5. Remember this 17mm screw has a pipe thread so don't try to bottom it out. Just get it hand tight, its not going anywhere.
I had to read the manuals and incubate this for a few days before I decided I could do this. The next time will be easy. Notice I bought two seals and gaskets...And if I can do it, anybody can. Now, on to the next chore. |
JawjaPorsche |
Oct 29 2014, 08:12 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Great Job! Pictures really help. (IMG:style_emoticons/default/beerchug.gif)
cpavlenko |
Oct 29 2014, 08:19 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
That just looked to simple, great job. (IMG:style_emoticons/default/beerchug.gif) also, great pictures.
Cap'n Krusty |
Oct 29 2014, 08:56 PM
An admin needs to move this to the classic threads forum.
The Cap'n |
Kansas 914 |
Oct 30 2014, 10:19 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
An admin needs to move this to the classic threads forum. The Cap'n (IMG:style_emoticons/default/agree.gif) Even I could do this repair following this well documented guide! |
zipedadoo |
Oct 30 2014, 01:27 PM
Member Group: Members Posts: 135 Joined: 23-January 14 From: Arizona Member No.: 16,921 Region Association: None |
Wish I had seen this before I did mine.........I didn't know about or see that bolt to access the roll pin. Would have made it so much easier.
boxsterfan |
Oct 30 2014, 02:04 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
But were you able to get the header back on? (IMG:style_emoticons/default/popcorn[1].gif)
eyesright |
Nov 2 2014, 05:49 PM
Wish I had seen this before I did mine.........I didn't know about or see that bolt to access the roll pin. Would have made it so much easier. Hmmm, that sounded intriguing so today I uncovered my '72 and looked at the shifter rod housing. It is leaking also and ...NO BOLT! I was a little suspicious the other day because the bolt had been shortened with a hack saw. Sooo, some DAPO, wisely perhaps, had drilled and tapped this roll pin access hole just to make my job easier, do you s'pose? Anyway, I figured it would be leaking which is why I bought two seals and gaskets, but this job will be a bit of a chore getting the roll pin out. Dr. Evil or any others, have you seen this roll pin hole before? Seems like a good idea.... |
Dr Evil |
Nov 5 2014, 08:22 AM
Send me your transmission! Group: Members Posts: 23,029 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Nope, that bolt is new to me, but a nice mod.
You can put the trans in gear and it will give you a shot at the roll pin without having to take off the tail cone. Remove the shift rod and you can rotate the internal rod a little more. That seal was nashtay. Excellent write up with picks, too bad everyone doesnt have that hole/bolt. |
Lo-Fi Version | Time is now: 20th September 2024 - 07:02 PM |
