Tail shifter leak, so I fixed it. |
eyesright |
Oct 29 2014, 06:22 PM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
I bought this -6 conversion project on Ebay too many years ago. It finally got off jackstands and I filled the transmission with GL-5. The next morning I found a good sized puddle under the shift rod. It wasn't the first "au krappe" moment for this project.
So I drained the oil. I would like to have saved it but it was getting too complicated... |
zipedadoo |
Oct 30 2014, 01:27 PM
Member Group: Members Posts: 135 Joined: 23-January 14 From: Arizona Member No.: 16,921 Region Association: None |
Wish I had seen this before I did mine.........I didn't know about or see that bolt to access the roll pin. Would have made it so much easier.
eyesright |
Nov 2 2014, 05:49 PM
Wish I had seen this before I did mine.........I didn't know about or see that bolt to access the roll pin. Would have made it so much easier. Hmmm, that sounded intriguing so today I uncovered my '72 and looked at the shifter rod housing. It is leaking also and ...NO BOLT! I was a little suspicious the other day because the bolt had been shortened with a hack saw. Sooo, some DAPO, wisely perhaps, had drilled and tapped this roll pin access hole just to make my job easier, do you s'pose? Anyway, I figured it would be leaking which is why I bought two seals and gaskets, but this job will be a bit of a chore getting the roll pin out. Dr. Evil or any others, have you seen this roll pin hole before? Seems like a good idea.... |
Lo-Fi Version | Time is now: 21st May 2024 - 08:57 AM |
