> JWest Engineering trunk hinge kit, Which way does it go ?
pilothyer
post Oct 30 2014, 05:17 PM
I know there is a left and right side, but which way ? The instructions include a hand drawn picture that doesn't clearly show the orientation..........Does anyone have a picture of either side installed on your car........Thanks in advance.
EdwardBlume
post Oct 30 2014, 05:26 PM
I don't know.
Please take lots of Picts and show your installation if you can. I need to do this on Dads car.
wes
post Oct 30 2014, 05:59 PM
wes
Attached Image driver side, cutout is up, adjustment bolt at bottom
wes
post Oct 30 2014, 06:05 PM
wes
QUOTE(pilothyer @ Oct 30 2014, 04:17 PM) *
sorry for poor pictures
passenger side,Attached Image
pilothyer
post Oct 30 2014, 11:33 PM
wes........I really appreciate the pics, but I am still not sure about which side goes where. If you look at the picture of the pair I have you will notice that one end is angled and the other end is straight. I am assuming they were cut this way for a reason and need to know which way they go.
wes
post Oct 31 2014, 12:21 AM
wes
Well I'll look tomorrow! It seems to me there was no left and right just at the top has to be where the hinges are as you have them in photo.
ejm
post Oct 31 2014, 04:08 AM
I can see the light at the end of the tunnel
It's been a while since I've installed a set but I seem to recall that if you separate the mount from the backing plate they are marked on the back with a Sharpie. When installing you need to position them so the bolts don't go thru the double walled area under the sail panel.
JWest
post Oct 31 2014, 06:45 AM
QUOTE(pilothyer @ Oct 30 2014, 06:17 PM) *
I'm confused about a drawing, I've never drawn it and my instructions include a picture of the left side, oriented to show the alignment.
In the picture you can see the vertical support bracket, the hinge, and the stamping for the 914/6 oil filler. The angled side of the bracket is to the rear. The picture is taken with the trunk lid closed and shows 3 of the four holes can be accessed for drilling. Once these three are installed, the trunk can be raised, moving the hinge away so the last hole can be drilled.
Since the pivot is installed with the deck lid closed and aligned, it really does not matter how it is oriented as long as you can access the holes for installation. The picture gives the general idea.
pilothyer
post Oct 31 2014, 08:28 AM
Thanks for the information and the picture.
pilothyer
post Oct 31 2014, 09:45 AM
QUOTE(JWest @ Oct 31 2014, 07:45 AM) *
James...........I bought my set from someone that didn't use them, but advertised them as directions included. The directions were kinda cartooney . After your reply I followed the link to your web site and noticed that you have the instructions there available for print....Thanks again for your reply and thanks to all for the help.
wes
post Oct 31 2014, 11:56 AM
wes
Looks like your good to go!
- Lo-Fi Version Time is now: 18th May 2026 - 04:15 AM
