JWest Engineering trunk hinge kit, Which way does it go ? |
pilothyer |
Oct 30 2014, 05:17 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I know there is a left and right side, but which way ? The instructions include a hand drawn picture that doesn't clearly show the orientation..........Does anyone have a picture of either side installed on your car........Thanks in advance.
ejm |
Oct 31 2014, 04:08 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
It's been a while since I've installed a set but I seem to recall that if you separate the mount from the backing plate they are marked on the back with a Sharpie. When installing you need to position them so the bolts don't go thru the double walled area under the sail panel.
Lo-Fi Version | Time is now: 16th May 2024 - 11:26 PM |
