Engine compartment latch, Best way to keep this from popping up...? |
jim_hoyland |
Oct 30 2014, 06:27 PM
Get that VIN ? Group: Members Posts: 9,278 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The rear engine compartment lid started popping open whenever I go over a bump. It appears that the L-shaped piece that screws into the lid is just barely catching the latch.
I was wondering if a slightly longer L-shaped piece could be made up ? Was tring to think of something that could be modified. I can also loosen the lids bolts and slide it back a little. Any thoughts here ? |
Bob L. |
Oct 30 2014, 06:41 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Can you adjust the latch up a tad. It sounds like it's not catching all the way.
Might also be dirty and not moving smoothly. |
bdstone914 |
Oct 30 2014, 06:47 PM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Can you adjust the latch up a tad. It sounds like it's not catching all the way. Might also be dirty and not moving smoothly. The adjustment is up and down. Can you see if the L part is centered going into the latch? When the lid ups up it the latch still in the closed position ? If it is the latch I have lots of plated ones. There should also be a washer between the latch and the mounting surface. You could shim it out moving the latch toward the front of the car to engage the L better. Bruce |
Lo-Fi Version | Time is now: 10th May 2024 - 11:56 AM |
