Engine compartment latch, Best way to keep this from popping up...? |
jim_hoyland |
Oct 30 2014, 06:27 PM
Get that VIN ? Group: Members Posts: 9,278 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The rear engine compartment lid started popping open whenever I go over a bump. It appears that the L-shaped piece that screws into the lid is just barely catching the latch.
I was wondering if a slightly longer L-shaped piece could be made up ? Was tring to think of something that could be modified. I can also loosen the lids bolts and slide it back a little. Any thoughts here ? |
TheCabinetmaker |
Oct 31 2014, 04:13 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The latch rod is also adjustable front to rear. Loosen the nut, slide it to the rear and tighten the nut.
jim_hoyland |
Oct 31 2014, 05:50 AM
The latch rod is also adjustable front to rear. Loosen the nut, slide it to the rear and tighten the nut. Thanks; it's been so long since I've had this happen I forgot about that. Will try that first. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 9th May 2024 - 07:02 PM |
