Engine compartment latch, Best way to keep this from popping up...? |
jim_hoyland |
Oct 30 2014, 06:27 PM
Get that VIN ? Group: Members Posts: 9,278 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The rear engine compartment lid started popping open whenever I go over a bump. It appears that the L-shaped piece that screws into the lid is just barely catching the latch.
I was wondering if a slightly longer L-shaped piece could be made up ? Was tring to think of something that could be modified. I can also loosen the lids bolts and slide it back a little. Any thoughts here ? |
jim_hoyland |
Oct 31 2014, 04:33 PM
It was the latch rod (IMG:style_emoticons/default/smile.gif) The nut was loose enough for the rod to slide a away from the latch. Put a drop of red lock-tite on the threads, tightened up the nut, and went for a test drive on the worst road I could find. Perfecto (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 10th May 2024 - 10:55 AM |
