Fuel Injector Hoses, Tried to search but times out |
Allan |
Jan 30 2005, 08:03 PM
Anybody know where to get the little elbow hoses that go to the injectors? Checked PP and GPR but no listing.
Bleyseng |
Jan 30 2005, 08:53 PM
Porsche or AA
Rhodes71/914 |
Jan 30 2005, 08:57 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Just use your regular fuel line and make them a little longer. Have to pull the fuel rails out of the way when putting the engine in but other than that it works fine.
Unless of course you want to spend the extra cash. |
markb |
Jan 30 2005, 08:58 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) I just did the ones on the Black car & did exactly that. |
newdeal2 |
Jan 30 2005, 09:01 PM
Unregistered |
Same here...but be careful not to kink them or get them jammed while installing the engine. I ended up pinching one and it leaked. (IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
Joe Bob |
Jan 30 2005, 09:04 PM
You will have to grind the brass bezels off and use the correct hose clamps top and bottom....
Rhodes71/914 |
Out of curiosity I checked AA, $13.20 EACH!
Allan |
Jan 30 2005, 10:23 PM
The bezels have already been removed. PO must have replaced them at one time. Luckily they used the good fuel line clamps. Thanks guys. |
newdeal2 |
Jan 30 2005, 10:28 PM
Unregistered |
BTW...make sure you check the clamps through out the system during break in. You don't want them leaking...anywhere! Spring for an in- line pressure gauge too. It will give you great results during tuning. |
Mueller |
Jan 30 2005, 11:21 PM
I got mine from High Performance House in Redwood City...not sure why you never try there??? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
make sure you use the correct FI hose clamps, not the generic hose clamps sold at Kragens and such... |
DJsRepS |
Feb 4 2005, 07:10 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
A little longer works but you need the yellow fuel lines in a yellow car. (yellow heat shrink tubing over stock black lines)
DJsRepS |
Feb 4 2005, 07:12 AM
Mine are soo short they are straight.
DJsRepS |
Feb 4 2005, 07:13 AM
Just make the yellow lines longer!
RustyWa |
Feb 4 2005, 12:40 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) You are going to catch crap for using those hose clamps!! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
martinef1963 |
Feb 4 2005, 12:45 PM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
Just wondering cause I'm going to change two of my injectors - because the fuel is pumped in their by "pressure" - what can be expected when you disconnect on of these hoses from let's say the FI rail?
thanks, the rookie (again). |
TheCabinetmaker |
Feb 4 2005, 12:48 PM
Wouldn't be the first time! |
TheCabinetmaker |
Feb 4 2005, 12:50 PM
The system can hold pressure for while, Just relieve the pressure at one point where you can catch the fuel in something, or wait 30 minutes after shuting the pump off. |
DJsRepS |
Feb 7 2005, 05:39 AM
RustyWa... I have caught crap in fact I had my first one leak all over the top of the motor it was the cold start injector right beside the dist. Good place to leak gas. I went straight to Ricks VW in Sarasota Fl and he said they were fine just check them more often. I did not quite belive him with all that raw fuel all over my motor near the distributer. He said that is all he uses and cant help me get the OEM ones. I will have to check PP and see if they have a set. Im ready to switch now.
Porsche Rescue |
Feb 7 2005, 10:00 AM
You can get proper (not OE but designed for FI/high pressure, dont' cut) at FLAPS.
Rhodes71/914 |
Feb 7 2005, 10:50 AM
You know what, I tried at my FLAPS and they looked at me like I was crazy asking for something different than the standard hose clamps. The line I got was "these will work just fine". Luckily between the 2 motors I have I came up with enough to do one complete. |
Lo-Fi Version | Time is now: 15th May 2024 - 08:26 AM |
