Ideas for, cast aluminum parts |
Kevin@ojai.net |
Jan 31 2005, 03:35 AM
Member Group: Members Posts: 158 Joined: 9-July 03 From: Ventura & Chico, CA Member No.: 899 |
For my Fluid Metallurgy class I get to make up some molds and cast a few parts. Does any one have any ideas of parts for the teener that could be cast?
-Kevin |
sj914 |
Jan 31 2005, 03:53 AM
Foglight/horn grill
ArtechnikA |
Jan 31 2005, 06:00 AM
2,0 cylinder heads ...
nein14-6 |
Jan 31 2005, 06:15 AM
Member Group: Members Posts: 93 Joined: 4-October 04 From: Mount Airy, MD Member No.: 2,883 |
How about the cross bar for the front suspension
machina |
Jan 31 2005, 06:47 AM
the 4-cyl motor mount bar. the stock iron unit weighs a ton.
ChrisFoley |
Jan 31 2005, 07:15 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I wouldn't trust the suspension mounting or the engine support to a cast part.
914efi |
Jan 31 2005, 08:13 AM
Member Group: Members Posts: 140 Joined: 14-June 04 From: Westport,MA Member No.: 2,204 Region Association: None |
The headlight grilles are a good idea except that you need left and right.
URY914 |
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,578 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
A personal fav of mine would be a outside door handle "flapper" piece, the piece that pivots when you pull on the handle is no longer being sold.
Paul |
Brando |
Jan 31 2005, 02:19 PM
If you're going to do an engine bar... any way you can do high-pressure injection molding, or forging? Might almost be better to mill one out of high-grade aluminum...
greg.treadway |
Jan 31 2005, 02:26 PM
914 Nut Group: Members Posts: 282 Joined: 16-December 04 From: Marietta, GA Member No.: 3,295 |
You mean this door flap?
(IMG:http://autoatlanta.net/itemgraphics/12420-1.jpg) Click here for more info... |
914werke |
Jan 31 2005, 02:44 PM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Isnt the Frt. x-bar off of the later taildrager cast allready? |
ArtechnikA |
Jan 31 2005, 02:50 PM
from '73[-ish] on, yup. that's a much less critical item, tho, end even those flex in normal service. |
Carlitos Way |
Jan 31 2005, 02:57 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
oil filler neck, gas cap, off the top of my head. Don't shoot me if these won't work. I have NO IDEA what can be cast or not.
Aaron Cox |
Jan 31 2005, 02:59 PM
please do this!!! |
Rog914 |
Jan 31 2005, 03:12 PM
914 Fanatic Group: Members Posts: 129 Joined: 5-January 03 From: Reisterstown,Md Member No.: 93 |
Something simple like the center visor mount w/steel pin but make sow you can adapt or bolt-on a new style rear veiw mirrow. Maybe even one of those electronic day/night type.
Something to think about. Ralph |
jd74914 |
Jan 31 2005, 03:23 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) A gas cap would be cool. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) So would an oil filler cap This post has been edited by jd74914: Jan 31 2005, 03:42 PM |
Mueller |
Jan 31 2005, 03:29 PM
here you go.....make an aluminum clutch line wheel:
sorry, I cannot find a larger picture..... how do plan on making the mold? need a STP file?
what kind of motor do you have?? those are 2 totally different parts, one should not affect the other ????? Attached image(s) |
davep |
Jan 31 2005, 03:32 PM
I have actually considered this a bit. I just had a tool made up to take the nuts off of the front struts that hold the shock in place. It was very expensive to machine. A cast tool may be strong enough. Also one for the ball joint nut. I can make up the part in plastic no problem. I'd have to know the shrink rate though to make it the proper size.
spunone |
Jan 31 2005, 03:37 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
What type of mold Sand cast or what if sand cast part is'nt go (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) nna be pretty
Mueller |
Jan 31 2005, 03:38 PM
how about center caps for the 4-lug Fuchs and Mahles?? instead of just a plain cap, have 914 cast into it???
Lo-Fi Version | Time is now: 15th May 2024 - 01:34 PM |
