Kevin@ojai.net
Jan 31 2005, 03:35 AM
For my Fluid Metallurgy class I get to make up some molds and cast a few parts. Does any one have any ideas of parts for the teener that could be cast?
-Kevin
sj914
Jan 31 2005, 03:53 AM
Foglight/horn grill
ArtechnikA
Jan 31 2005, 06:00 AM
2,0 cylinder heads ...
nein14-6
Jan 31 2005, 06:15 AM
How about the cross bar for the front suspension
machina
Jan 31 2005, 06:47 AM
the 4-cyl motor mount bar. the stock iron unit weighs a ton.
ChrisFoley
Jan 31 2005, 07:15 AM
I wouldn't trust the suspension mounting or the engine support to a cast part.
914efi
Jan 31 2005, 08:13 AM
The headlight grilles are a good idea except that you need left and right.
URY914
A personal fav of mine would be a outside door handle "flapper" piece, the piece that pivots when you pull on the handle is no longer being sold.
Paul
Brando
Jan 31 2005, 02:19 PM
If you're going to do an engine bar... any way you can do high-pressure injection molding, or forging? Might almost be better to mill one out of high-grade aluminum...
greg.treadway
Jan 31 2005, 02:26 PM
914werke
Jan 31 2005, 02:44 PM
QUOTE (Racer Chris @ Jan 31 2005, 05:15 AM) |
I wouldn't trust the suspension mounting or the engine support to a cast part. |
Isnt the Frt. x-bar off of the later taildrager cast allready?
ArtechnikA
Jan 31 2005, 02:50 PM
QUOTE (rdauenhauer @ Jan 31 2005, 03:44 PM) |
Isnt the Frt. x-bar off of the later taildra[g]ger cast already? |
from '73[-ish] on, yup.
that's a much less critical item, tho, end even those flex in normal service.
Carlitos Way
Jan 31 2005, 02:57 PM
oil filler neck, gas cap, off the top of my head. Don't shoot me if these won't work. I have NO IDEA what can be cast or not.
Aaron Cox
Jan 31 2005, 02:59 PM
QUOTE (sj914 @ Jan 31 2005, 02:53 AM) |
Foglight/horn grill |
please do this!!!
Rog914
Jan 31 2005, 03:12 PM
Something simple like the center visor mount w/steel pin but make sow you can adapt or bolt-on a new style rear veiw mirrow. Maybe even one of those electronic day/night type.
Something to think about.
Ralph
jd74914
Jan 31 2005, 03:23 PM
QUOTE |
oil filler neck, gas cap, off the top of my head. Don't shoot me if these won't work. I have NO IDEA what can be cast or not |
A gas cap would be cool. So would an oil filler cap
Mueller
Jan 31 2005, 03:29 PM
here you go.....make an aluminum clutch line wheel:
sorry, I cannot find a larger picture.....
how do plan on making the mold? need a STP file?
QUOTE |
So would an oil filler cap (only problem is the dipstick) |
what kind of motor do you have?? those are 2 totally different parts, one should not affect the other ?????
davep
Jan 31 2005, 03:32 PM
I have actually considered this a bit. I just had a tool made up to take the nuts off of the front struts that hold the shock in place. It was very expensive to machine. A cast tool may be strong enough. Also one for the ball joint nut. I can make up the part in plastic no problem. I'd have to know the shrink rate though to make it the proper size.
spunone
Jan 31 2005, 03:37 PM
What type of mold Sand cast or what if sand cast part is'nt go
nna be pretty
Mueller
Jan 31 2005, 03:38 PM
how about center caps for the 4-lug Fuchs and Mahles?? instead of just a plain cap, have 914 cast into it???
jd74914
Jan 31 2005, 03:40 PM
QUOTE |
what kind of motor do you have?? those are 2 totally different parts, one should not affect the other ????? |
LOL, I'm really tired. Its fixed now
I like the 914 center caps idea, that would be sweet
spunone
Jan 31 2005, 03:47 PM
Yeah center caps sounds very cool
Mueller
Jan 31 2005, 03:50 PM
QUOTE |
I like the 914 center caps idea, that would be sweet |
QUOTE |
Yeah center caps sounds very cool |
i've got 2 set sold for you already...what kind of royalties should I expect?? LOL
bperry
How about
- an actual small scale model of the car itself - like the chocolate ones.
- 5 bolt style hubcap center adapter for the factory 4 bolt Fuchs
Would sit between the hubcap and the wheel to give a slight
outward extension / add clearence for the front hubs.
--- bill
Kevin@ojai.net
Jan 31 2005, 04:42 PM
Cool ideas -- keep 'em coming.
I'm probably going to make a wood pattern, either on the cnc or manually -- it depends on what I want to make. I wouldn't want to make anything "structural" where you or the car could get f-d up if the part failed (like an engine bar).
Mike: send me the file and I'll take a look...
I like the idea of the center cap for the Fuchs -- that could look cool all polished up or powdercoated!
Weren't the original grills plastic? Why would you want them aluminum -- it would be heavier!
I also thought making little 914 keychain toys might be fun, but it would kinda be a PIA to do, and have them come out nice.
-Kevin
McMark
Jan 31 2005, 04:43 PM
A scale model of a fuch wheel as a cool paper weight.
Mueller
Jan 31 2005, 04:49 PM
QUOTE (McMark @ Jan 31 2005, 03:43 PM) |
A scale model of a fuch wheel as a cool paper weight. |
I was going to suggest that as well, thought I was the only one goofy enough to want one
you could turn it into a business card holder.........
914werke
Jan 31 2005, 05:27 PM
ZachP
Jan 31 2005, 08:41 PM
Angelina Jolie
ArtechnikA
Jan 31 2005, 08:47 PM
QUOTE (Russian019 @ Jan 31 2005, 09:41 PM) |
Angelina Jolie |
speaking of which, i note that 'Gia" is now out on unrated DVD ...
if you should happen to like that sort of thing :-)
IronHillRestorations
How about a 916 transmission tail housing? Last I heard Velios Co. went toes up.
URY914
Jan 31 2005, 09:03 PM
Sorry, I saw Pelican didn't sell them any more.
Gee, would I want to risk ordering from AA?
Brent
Feb 1 2005, 12:12 AM
QUOTE (Aaron Cox @ Jan 31 2005, 12:59 PM) |
QUOTE (sj914 @ Jan 31 2005, 02:53 AM) | Foglight/horn grill |
please do this!!! |
Please do this!!!! Plastic grills ...that cost nos about $250 for the pair at least.
SpecialK
Feb 1 2005, 12:42 AM
Shift knob with 914 logo.......of course, if you left your top off in the sun it would be more of a branding iron than a shift knob.
Center caps.....yeah, center caps.
Brent
Feb 1 2005, 01:45 AM
QUOTE (Special_K @ Jan 31 2005, 10:42 PM) |
...would cast al get that hot in the sun??? I'm down for a 914 brand! The question would be where I would / could put it
Kevin@ojai.net
Feb 1 2005, 02:01 AM
If some one sends me either a solid file, a sketch, or the actual part of the horn/light grills I'll take a look and see if I can do them. My teener is not available, and my grills were only horn, not fog light/horn grills.
-Kevin
Brent
Feb 1 2005, 02:08 AM
Sweet. I will peruse my pics I have on file. Thats the best I can do. My poor grills would not be suitable for display on this site
Brent
Feb 1 2005, 03:05 AM
I found nothing dammit! However
...I did find some nice pics on the Pelican catalog. I have mine in storage, so maybe I will take some pics and post several angles and take some measurements.
Anyone have a sacrificial one they can send in for the cause???? Then you can take a straight cast.
Pelican grill1Pelican Grill 2
SpecialK
Feb 1 2005, 03:13 AM
QUOTE (Brent @ Jan 31 2005, 11:45 PM) |
[/QUOTE] ...would cast al get that hot in the sun??? |
In Missouri it does....that's why I keep my beer in a cooler (okay.....beer cans aren't "cast" aluminum until they're empty! )
Brent
Feb 1 2005, 03:16 AM
I'll drink to that!
With a brand, maybe I could get mistaken for an Omega..... maybe not.
SpecialK
Feb 1 2005, 03:28 AM
Not sure what an "Omega" is.........but that sure is a cute Avatar you're sportin' there (and that's not the beer talkin'
Oh crap, the O.T. police are going to get me
.......yeah, 914 shift knob!
bperry
Feb 5 2005, 03:10 AM
Another idea:.
- Seat Adjuster handles. The only replacements I've seen have been nylon.
--- bill
