Interior remodeling |
rtalich |
Nov 9 2014, 10:46 AM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
Found a big block of foam and thought I would see about making my own center console. Here's the progress so far. This will be my first project using fiberglass... any pointers or advice? Should I use cloth or mat? Should I paint or use color resin?
Thanks Rob Attached thumbnail(s) |
McMark |
Nov 9 2014, 10:53 AM
Mat will work fine. Don't try to do it all in one large piece. It will lay down better with small sections, just overlap them like paper-mache.
Bodywork and paint afterwords is the best way to make it look smooth. Chances are it's not going to be very pretty after laying the fiberglass. Technically, colored resin (or Gel Coat) is meant to be used in a mold that has been polished. You spray in the gel coat first, and then lay in the fiberglass mat after that. Then once you pop the whole assembly out of the mold you see the color. Assuming you're planning on laying up over the foam, your finished product will show a ton of mat-weaving. So bondo will be necessary to smooth it out. Oh, and if you're laying the fiberglass over the foam, make sure the resin doesn't eat the foam, if it does, wrap the foam in plastic wrap first. |
McMark |
Nov 9 2014, 10:55 AM
Oh and you might as well stick a 6.5" subwoofer in there. (IMG:style_emoticons/default/happy11.gif)
http://www.jlaudio.com/6w3v3-4-car-audio-w...r-drivers-92145 (IMG:http://www.914world.com/bbs2/uploads_offsite/www.polimax.co.uk-419-1415552145.1.jpg) |
rtalich |
Nov 9 2014, 12:03 PM
Thanks Mark! If I used cloth and then a few coats of resin, would that save me from having to use bondo?
A subwoofer is definitely in the plan too!! |
PanelBilly |
Nov 9 2014, 12:12 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Wrap it in vinyl and make an upholstered cap
porschefile2010 |
Nov 9 2014, 12:19 PM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
Interesting job ahead of you. Regardless of what you lay over the foam you are going to need to fill and fair the job with a polyester fairing compound.
If it were me I would do a test as McMark suggests to make sure your resin is compatible with the foam. Then I would lay on a layer of Chopped strand matt CSM which will take the curves and recesses way better than cloth. When the resin has started hardening and the CSM is not moving, follow with your filler, leave to harden and then fair it with a small longboard of sandpaper. You will need to refill and fair until it is right. Also make sure the foam is square and not bent in any way-it's a bit hard to straighten it when it has glass on it. Good luck. |
Bob L. |
Nov 9 2014, 12:27 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
How are you going to Handle the hole for the shifter?
Gated shifter? |
veekry9 |
Nov 9 2014, 04:45 PM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
http://www.fiero.nl/forum/Forum3/HTML/000091-53.html
Check this out for methods,research the grp tech boards. http://www.westsystem.com/ss/ As a first time user,you will make a mess.Clean is it. Plan your work,work your plan.Write it down even as steps,use a timer. Keep the toxic stuff off your skin,wear a mask. Have fun. |
rtalich |
Nov 9 2014, 06:01 PM
McMark |
Nov 9 2014, 06:39 PM
Just plan on using bondo, cause it's gonna happen.
barefoot |
Nov 10 2014, 11:41 AM
Senior Member Group: Members Posts: 1,275 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
QUOTE Check this out for methods,research the grp tech boards. http://www.westsystem.com/ss/ As a first time user,you will make a mess.Clean is it. Plan your work,work your plan.Write it down even as steps,use a timer. Keep the toxic stuff off your skin,wear a mask. Have fun. Recommend using epoxy. I've used quite a bit of the West system resins over foam with good results. Polyester resin eats some foams. i used fabric rather than mat as it will leave a smoother finish two plys of a 6 oz fabric should do well. you can wrap the outside in visiqueen which will provede a smooth exterior if you get a good wrinkle free wrap. If you want to be sexy, use carbon fiber fabric instead of F/G. I did a whole boat interior that way |
CptTripps |
Nov 10 2014, 12:56 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Very cool. Where can I buy some of this foam? That'd work very well for my plans as well.
veekry9 |
Nov 10 2014, 01:34 PM
http://www.freemansupply.com/
http://www.freemansupply.ca/products.htm http://www.fibreglast.com/category/tooling...d-tooling-dough https://www.google.ca/#q=polyurethane+model...hio&spell=1 Long ago,there was only 1 or 2 places to find a supplier for small quantities. With all of this,there is a great resource. |
rtalich |
Nov 10 2014, 02:31 PM
Thanks for all the suggestions so far!! At this point I'm thinking I will bondo over the foam and get a nice good base. Then fabric or CF over that. Then several coats of resin sanding in between to get a nice smooth surface. I will probably cut the peice to make a lid and compartment before bondo and glass.
I found this block of foam while driving by a place a while ago. They were throwing a bunch of these blocks out. Asked if I can have one. I've had it in the garage for a coulple years and decided it's time to make something out of it. |
rtalich |
Nov 11 2014, 06:34 PM
A bit more progress.
altitude411 |
Nov 11 2014, 07:59 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
Very cool. Where can I buy some of this foam? That'd work very well for my plans as well. Here's some foam blocks from a taxidermy supply. It's easy to use, carves with a knife and sands nicely with drywall sanding screen. (Not so much dust) http://www.vandykestaxidermy.com/Search.aspx?k=foam%20block |
ThePaintedMan |
Nov 11 2014, 08:08 PM
Thanks for all the suggestions so far!! At this point I'm thinking I will bondo over the foam and get a nice good base. Then fabric or CF over that. Then several coats of resin sanding in between to get a nice smooth surface. I will probably cut the peice to make a lid and compartment before bondo and glass. Your idea looks awesome so far, but I think you have it a little backward (at least from how folks typically fabricate). Foam first. Then lay your fiberglass over. Then finish with bondo and primer. You don't want to lay bondo over the foam because it won't have a firm surface to adhere to. This could be a real problem as it sits in the sun and cures over the years. Generally when you make a one-off part you always finish fiberglass with a skim coat of bondo/filler. Resin by itself won't leave you with a great surface to prime and paint without roughing it up. And trying to sand resin with anything finer than 120 grit is basically pointless. That's why your final step will always be bondo and primer. Unless of course you have a mold, like Mark was talking about. Then no filler should be necessary - just gel coat. |
porschefile2010 |
Nov 12 2014, 12:19 PM
And for a first time amateur build I really think you should use polyester with Chopped strand matt. Make it resin rich and it will handle those curves and radiuses better than cloth and you are going to have to use filler anyway and do some fairing after so save yourself the grief. Epoxy is great but you need peelply if you want cloth to hold corners and that starts to get tricky. Once again good luck. Will look forward to seeing the finished job. |
rtalich |
Nov 12 2014, 12:33 PM
Thanks!!! I will follow the steps and advice above.
McMark |
Nov 12 2014, 12:50 PM
Consider some access to adjust the shifter. If you ever have to it'll be a PITA. (IMG:style_emoticons/default/wink.gif)
QUOTE Then several coats of resin sanding in between to get a nice smooth surface. This is basically bondo, only it's more work and more of a PITA. Bondo is fiberglass resin with filler (talc) mixed in to thicken it. If it's too thick for your project, try glasing putty. It's resin with less filler, so it's smoother. The resin will run and drip and will build up thickness much more slowly. Glasing putty will fill the strand texture quickly and easily. |
Lo-Fi Version | Time is now: 19th May 2024 - 12:43 AM |
