> 2056 L - Jet Build advise request
pnewman
post Nov 12 2014, 06:26 PM
Time to rebuild my stock 1.8 L Jet
Keeping the L Jet.
Any recommendations with the 2056 build in regards to the L Jet
-such as cam choice and source etc.
-do's / don'ts from your experience.
-links to like build threads.
Thanks in advance.
914Sixer
post Nov 12 2014, 07:12 PM
Go to Jake Raby's store. Type4store.com
Jake Raby
post Nov 13 2014, 12:47 AM
Engine Surgeon
QUOTE(914Sixer @ Nov 12 2014, 05:12 PM) *
Its the LN Engineering Type 4 Store, has been for a year now :-)
Bleyseng
post Nov 13 2014, 09:15 AM
Aircooled Baby!
96mm P&C's
New Ham Heads with 42x36 valves
Raby 9590 cam
Porsche swivel feet adjusters
Chrome Moly pushrods
pnewman
post Nov 13 2014, 12:53 PM
QUOTE(Bleyseng @ Nov 13 2014, 09:15 AM) *
96mm P&C's
Raby 9590 cam
Thanks,
At least it seems as though I am on the right track.
Len Hoffman has given me a quote on converting my 1.8 liter heads
yep: 42x36
I have 96mm P&C's NOS laying around
Had a set of 1.7 rockers machined for the swivel feet adjusters
I have a set of swivel feet adjusters and nuts en route. "good" used Porsche oem.
...we'll see
THANKS FOR THE ADVISE ON THE CAM!
Was wondering if 9590 was too aggressive for the 1.8 liter L-Jet vs stock 2.0 cam. From what I have read some with this combination seemed to have L-Jet adjustment woes. :-(
ChrisFoley
post Nov 13 2014, 03:32 PM
I am Tangerine Racing
QUOTE(pnewman @ Nov 13 2014, 01:53 PM) *
I've successfully tuned 2.2L L-jet engines with more aggressive cam grinds than the 9590.
pnewman
post Nov 13 2014, 05:53 PM
QUOTE(Racer Chris @ Nov 13 2014, 03:32 PM) *
Thanks for the Vote of confidence Chris! (IMG:style_emoticons/default/beerchug.gif)
I wonder how smooth they idle.
Olympic 914
post Nov 13 2014, 06:44 PM
QUOTE(Bleyseng @ Nov 13 2014, 10:15 AM) *
96mm P&C's
Raby 9590 cam
You just described my build, with the addition of H-beam rods and a total balance job. I went with the RS+ heads. mine is the D-jet though, I think that might be near the max for the D-jet. maybe the L-jet can handle more.
Unfortunately it will be a while until the engine is installed in the car, So I can't give any observations of how it runs. (IMG:style_emoticons/default/confused24.gif)
But I think it should be a fun engine.
pilothyer
post Nov 13 2014, 07:35 PM
Try to get a 86 - 91 Vanagon 2.1 Liter throttle valve (50 mm throat as opposed to the 45 mm on the stock L-Jet) P/N 025 133 067. Lots of info available about this.
pilothyer
post Nov 13 2014, 08:52 PM
No hijack intended, but what happened to the Raby 9550 cam? and what is the difference between it and the 9590?
malcolm2
post Nov 13 2014, 09:48 PM
QUOTE(pilothyer @ Nov 13 2014, 08:52 PM) *
someone will know for sure, but I believe I heard that soon after I bought my 9550 it was improved and given a new number. Can't remember the number but maybe it is the 9590. Sorry no details and no confidence in the answer, but I bet I am somewhat right> only bet a nickel on it tho.
malcolm2
post Nov 13 2014, 09:49 PM
Jake Raby
post Nov 13 2014, 10:07 PM
Engine Surgeon
QUOTE(pilothyer @ Nov 13 2014, 06:52 PM) *
The 9550 was updated with different lobe separation and exhaust profile in 2011. We did this because the 9550 was old news and the 9590 provided more mid range power with lower running temps. Put simply, the 9590 is the next generation 9550.
That said, all the profiles and parts are now LN Engineering products, I sold the Type 4 Store last year. Thank goodness!
r_towle
post Nov 13 2014, 10:15 PM
Custom Member
What is the difference is head flow between the stock heads and the RS heads?
Curious how much change is occurring....
Jake Raby
post Nov 13 2014, 10:59 PM
Engine Surgeon
QUOTE(r_towle @ Nov 13 2014, 08:15 PM) *
On a 2056, about 15HP worth of difference back to back.
On the flow bench the peak flow is very similar, but where the flow peaks at is different and low lift flow and chamber filling is dramatically increased.
The biggest difference is the altered port flow margins between intake and exhaust ports. Remember, peak flow mans a lot less than where the flow is made and what intake : exhaust flow margins are.
These port flow margins work really well with the split duration cams that I developed as part of many engine combinations.
Here's a graph that was handy from the 2006 offerings, the RS is more refined now than this, but this is the general idea. Remember, this is dry flow data and doesn't show swirl, or tumble, or port velocity. But we have all that data as well.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.aircooledtechnology.com-1095-1415941456.1.jpg)
This post has been edited by Jake Raby: Nov 13 2014, 11:04 PM
r_towle
post Nov 13 2014, 11:04 PM
Custom Member
QUOTE(Jake Raby @ Nov 13 2014, 11:59 PM) *
On the flow bench the peak flow is very similar, but where the flow peaks at is different and low lift flow and chamber filling can be up by 35%.
And that increase in flow works ok with DJET?
That is kinda why I asked, guy above said he was going with Djet, just curious how it likes that.....cause it does not like a lot of change.....
Rich
Jake Raby
post Nov 13 2014, 11:13 PM
Engine Surgeon
This is the head that was developed to work with L jet as a primary objective. The L Jet doesn't recognize the changes the heads offer.
r_towle
post Nov 13 2014, 11:16 PM
Custom Member
Cool. one of the other poster said he built an engine with those heads running my favorite....Djet.
Just curious if I could try something new....different and push it a bit more...
Will wait to see how it runs in his car to see if it's worth pursuing the heads...but I might just to see if it can get a little bit more from djet.
r_towle
post Nov 13 2014, 11:17 PM
Custom Member
QUOTE(Olympic 1.7 @ Nov 13 2014, 07:44 PM) *
96mm P&C's
Raby 9590 cam
This guy...
Jake Raby
post Nov 13 2014, 11:26 PM
Engine Surgeon
9590+RS Plus & 8.5:1 with tight deck will make 110-115HP safely.
- Lo-Fi Version Time is now: 11th November 2026 - 02:46 AM
