4 lug billet hub adapters?, vented rotors |
zach914v8 |
Nov 16 2014, 12:29 AM
Member Group: Members Posts: 216 Joined: 26-November 10 From: Houston Member No.: 12,426 Region Association: Southwest Region |
Some years ago I read that brad Roberts was building these hubs that would allow us 4 lug guys the chance to use vented rotors. Apparently for some reason they can't be found anywhere. I have invested $$$ in aftermarket wheels and want to stay with 4 lugs.
Does anyone here have any information about these hubs? Maybe drawings or something, so I can have a set machined. Thanks Zach |
DRPHIL914 |
Nov 17 2014, 09:49 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I see that site also has 5 lug variety ! Vented . So would those work with stock calipers? I did the 5 lug conversion using the 4 lug drilled to 5 by Eric shea. So if I wanted to step up to have vented rotors these would work on my front with current set up?- I'm referring to the German ones (IMG:style_emoticons/default/smile.gif)
Attached image(s) |
bdstone914 |
Nov 17 2014, 10:42 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I see that site also has 5 lug variety ! Vented . So would those work with stock calipers? I did the 5 lug conversion using the 4 lug drilled to 5 by Eric shea. So if I wanted to step up to have vented rotors these would work on my front with current set up?- I'm referring to the German ones (IMG:style_emoticons/default/smile.gif) Not with stock calpiers. 911 M calipers or Alfa calipers would work. Or a 1978 BMW 320 I caliper. Might need the pad machined. They used vented rotors for 1 year only. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:38 PM |
