4 lug billet hub adapters?, vented rotors |
zach914v8 |
Nov 16 2014, 12:29 AM
Member Group: Members Posts: 216 Joined: 26-November 10 From: Houston Member No.: 12,426 Region Association: Southwest Region |
Some years ago I read that brad Roberts was building these hubs that would allow us 4 lug guys the chance to use vented rotors. Apparently for some reason they can't be found anywhere. I have invested $$$ in aftermarket wheels and want to stay with 4 lugs.
Does anyone here have any information about these hubs? Maybe drawings or something, so I can have a set machined. Thanks Zach |
ConeDodger |
Nov 18 2014, 12:58 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Mike,
Eventually, my car will be down at McMark's shop for the installation of the 915 transmission. They are building it right now. Once it is in the car, Mark is going to fabricate the cable shifter system. You are welcome to reverse engineer from my 5 lug AL hubs. As I said, these were just drilled and tapped for studs and they loosen up unless the wheels are holding them in place. That is the only thing I would engineer out of them. I believe mine use 914-6 rotors and I know it uses Alpha Romeo GTV-6 Aluminum calipers... So I have a very significant unsprung weight reduction in the front. |
zach914v8 |
Nov 18 2014, 01:07 PM
Just thinking out loud here, but the stock hub is just a solid piece of metal right? why couldn't we cut the rotor section off and machine the back of the hub to accept 911 rotors? Is this possible, or am I completely out of wack here?
stugray |
Nov 18 2014, 05:05 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Just thinking out loud here, but the stock hub is just a solid piece of metal right? why couldn't we cut the rotor section off and machine the back of the hub to accept 911 rotors? Is this possible, or am I completely out of wack here? The "hub/spindle" is connected to the brake disk by the "bell" or bowl shaped portion. My suggestion above was to cut off the disk (leaving some tabs) and bolt the wilwood rotor on. The stock piece is not a good candidate because if you cut off the disk and leave tabs, there is very little material thickness left where the tabs would meet the "bell". Plus what caliper you want to use would govern the required offset of the bolt-on rotor wrt the wheel mating surface. I would prefer the 914 caliper with the spacers to accommodate the vented rotors (essentially a 914-6 caliper?) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:43 PM |
