4 lug billet hub adapters?, vented rotors |
zach914v8 |
Nov 16 2014, 12:29 AM
Member Group: Members Posts: 216 Joined: 26-November 10 From: Houston Member No.: 12,426 Region Association: Southwest Region |
Some years ago I read that brad Roberts was building these hubs that would allow us 4 lug guys the chance to use vented rotors. Apparently for some reason they can't be found anywhere. I have invested $$$ in aftermarket wheels and want to stay with 4 lugs.
Does anyone here have any information about these hubs? Maybe drawings or something, so I can have a set machined. Thanks Zach |
69telecaster |
Nov 18 2014, 04:35 PM
Member Group: Members Posts: 101 Joined: 4-April 10 From: White Cloud, MI Member No.: 11,558 Region Association: None |
I would lean towards the use of some 'standard' aftermarket rotor and possibly caliper arrangement...less expensive, easy to find, and possibly lighter.
cm |
zach914v8 |
Nov 18 2014, 06:10 PM
I would lean towards the use of some 'standard' aftermarket rotor and possibly caliper arrangement...less expensive, easy to find, and possibly lighter. cm I with you on the rotor part. Rockauto is filled with cheap great calipers for cheap. Some decent calipers include... Cadillac cts-v 05-07 Acura TL and RL Turbo rx7 88-91 Volvo v70r and s60r Toyota trucks 79-84 These listed are all 4 piston calipers. The acura RL is interesting because it has a top bolt mount that I really like. Of course all these calipers used rotor of all different diameters and thickness. But that is why I think it would be cool to set a hub up for a wilwood rotor with like their 8 x 7 pattern. Then you could choose a caliper and rotor combo that works best for what you want/need. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:20 PM |
