> Replacing pushrod tube seals, Need some pointers for a weekend mechanic
boxsterfan
post Nov 16 2014, 02:09 PM
914's are kewl
So my pushrod tubes definitely have leaks. Is this job even reasonable to attempt with the engine in the car? Any pointers/tricks for someone who has never done this before?
pilothyer
post Nov 16 2014, 02:21 PM
QUOTE(boxsterfan @ Nov 16 2014, 02:09 PM) *
Read THIS
boxsterfan
post Nov 16 2014, 02:24 PM
914's are kewl
QUOTE(pilothyer @ Nov 16 2014, 12:21 PM) *
Read THIS
Awesome!! Thanks!!
rjames
post Nov 16 2014, 04:19 PM
I'm made of metal
A tip I learned while going through this a few weeks ago:
If the tubes don't come out easily- ie, your spending 1-2 hours trying to remove each one, stick a long socket down the tube , use vice grips to clamp the tube where the socket is and don't worry about trashing them. New tubes can be had for ~$15.
Clean well the ares where the seals rest and use a socket on an extension to tap the tubes in all the way. Engine oil is all you need on the seals.
- Lo-Fi Version Time is now: 18th June 2026 - 06:13 PM
