fuel pump question?, what is it?? |
porsche-tom |
Nov 16 2014, 02:48 PM
Member Group: Members Posts: 140 Joined: 7-March 13 From: jensen beach fl Member No.: 15,626 Region Association: None |
hello all i finally have a garage so i can start tearing into the 914. i have had problems with the fuel pump cutting out when its hot out(50 degrees or less it runs fine)i have taken out the gas tank which was full of dirt and debris and cleaned it. under the car right behind the fuel filter (where i would assume the pump should be) i found what has been making the rattling noise.... is this some kind of aftermarket fuel pump? i does not look like one i have ever seen.can anyone help me out?
CAR INFO- 1972 914 1.7 SINGLE CARB CONVERT |
PanelBilly |
Nov 16 2014, 02:59 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
That's the fuel pump that they used to replace the OEM unit
porsche-tom |
Nov 16 2014, 03:15 PM
OK, any recommendations on if i should just replace it wit the same pump or are there any better options. thank you very much
messix |
Nov 16 2014, 03:21 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
it's just a cheap run of the mill facet low pressure fuel pump.
Cap'n Krusty |
Nov 16 2014, 04:01 PM
A Pierberg rotary pump is better. Quieter, too. Mount it in a rubber ring (comes with the pump. I have one in my 911. Lotsa sources. CB Performance sell 'em, so does GPR.
The Cap'n |
Mike Bellis |
Nov 16 2014, 04:24 PM
Those fuel hoses look scary!
Nov 16 2014, 04:26 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'm surprised no one has commented on your cracked fuel hoses ... (IMG:style_emoticons/default/popcorn[1].gif)
(EDIT: I see Mike beat me to it) I second the CB Performance rotary pump, it's 100x better than the piece of crap you have there. (IMG:style_emoticons/default/smile.gif) This is the one you want: http://www.cbperformance.com/ProductDetail...roductCode=3193 (IMG:http://www.914world.com/bbs2/uploads_offsite/www.cbperformance.com-179-1416176797.1.jpg) |
porsche-tom |
Nov 16 2014, 05:00 PM
thanks guys and yes the fuel lines are getting replaced (IMG:style_emoticons/default/smile.gif)
clapeza |
Nov 16 2014, 06:39 PM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
Tangerine Racing offers a kit with their stainless steel fuel lines and a rotary pump:
http://www.tangerineracing.com/stainlessfuellines.htm ...while you're in there! |
porsche-tom |
Nov 22 2014, 12:15 PM
the rotary fuel pump arrived any pictures of where you mounted it?
Nov 22 2014, 12:49 PM
the rotary fuel pump arrived any pictures of where you mounted it? I actually mounted mine in the early stock location under the engine shelf in the back and used both the supply and return line to keep the fuel circulating and cooler. From your picture, it seems your old pump was in the front. Did you have the return line blocked off in that setup? (IMG:style_emoticons/default/idea.gif) |
porsche-tom |
Nov 22 2014, 12:57 PM
Yes the return line was blocked off. I might be able to put it in the same location (under the tank next to the master cylinder) but its a pretty small spot.has anybody put it the the trunk my the spare?
Nov 22 2014, 08:08 PM
Yes, that is another spot people have put it.
--DD |
porsche-tom |
Nov 28 2014, 11:08 AM
UPDATE- i pulled off the lower cover and tried to start it up and the bitch fired right up (IMG:style_emoticons/default/biggrin.gif) thank you all for the advice (IMG:style_emoticons/default/beer.gif)
porsche-tom |
Nov 28 2014, 11:10 AM
Lo-Fi Version | Time is now: 19th May 2024 - 03:46 AM |
