hello all i finally have a garage so i can start tearing into the 914. i have had problems with the fuel pump cutting out when its hot out(50 degrees or less it runs fine)i have taken out the gas tank which was full of dirt and debris and cleaned it. under the car right behind the fuel filter (where i would assume the pump should be) i found what has been making the rattling noise.... is this some kind of aftermarket fuel pump? i does not look like one i have ever seen.can anyone help me out?
CAR INFO- 1972 914 1.7 SINGLE CARB CONVERT Click to view attachment
