Using a Boxster Rear Hub for 5 Bolt Conversion, I think it will be EASY |
914Sixer |
Nov 19 2014, 06:10 PM
We all know that 69-73 911 rear hubs are getting scarce and pricey. I went out on a limb and bought a whole rear 99 Boxster assembly for $41 delivered on EBAY. It is a well known fact that the 914 and the Boxster use the same wheel bearing. So I figured it would be an easy swap. I drove the hub out of the bearing and started the comparison of the two hubs. I had a 69-73 911 rear hub and a -6 stub axle to use as a baseline. The Boxster hub has the same splines as the 911/914-6 stub axle so it was a drop in fit. One down, so I put them side by side to find out they are the same height. Now have two down, the last check was to set the rotors on both hubs to see where we were at. Bingo, they matched up. So the stub, the hub and the height are all the same. HOWEVER, there is one area to be addressed. the -6 stub sticks up about 5mm past the center of the hub. It is going to require a spacer to fill in the area so the washer and nut will tighten down. I am thinking that the one that Patrick Motor sports will do the trick. I think it will be worth trying because I am using Boxster wheels.
Tell me what you think. Attached image(s) |
914Sixer |
Jan 26 2015, 08:30 PM
Ok, here is the last of what I have found out using the Boxster and later 993 axles. The 911 and Boxster axle are the same length, are hollow tubed and use a 28 spline. The 911 axle is 32 mm thick and the Boxster is 28mm thick. Both are to long for 914 use. The Boxster S inner CV is a 911.332.030.01 , 108mm and 32mm thick. It is used in bunch of Porsche applications including the 930 Turbo. The 911 inner CV only had a Lobro part 7253150199001 and it is only 28mm thick. Both CV's used a 928.332.293.02 boot.
I had some 110mm 911 stub axles so I bolted the CV's up. I see no reason why the CV would not work for this application with joint gasket. The outer stubs are a completely different item. The flanges are crimped on and no replacements are available. CV joint cup could be machined off and holes drilled. Not cost effective to use them. The overall height is the same but each is machined differently. In summation the only useable part would be the Boxster hub. The 914-6 rotor would have to be drilled and screw holes countersunk to allow the hub to be screwed to the hub. The 911/944 stub axle will required a 8mm spacer at the top of the stub axle so it can be tightened down. So, I spent some money and learned some new information. It seemed like a good plan at the time but NOT worth the cost of modification required to make it all work. Attached image(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 02:02 AM |
