Using a Boxster Rear Hub for 5 Bolt Conversion, I think it will be EASY |
914Sixer |
Nov 19 2014, 06:10 PM
914 Guru Group: Members Posts: 8,882 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
We all know that 69-73 911 rear hubs are getting scarce and pricey. I went out on a limb and bought a whole rear 99 Boxster assembly for $41 delivered on EBAY. It is a well known fact that the 914 and the Boxster use the same wheel bearing. So I figured it would be an easy swap. I drove the hub out of the bearing and started the comparison of the two hubs. I had a 69-73 911 rear hub and a -6 stub axle to use as a baseline. The Boxster hub has the same splines as the 911/914-6 stub axle so it was a drop in fit. One down, so I put them side by side to find out they are the same height. Now have two down, the last check was to set the rotors on both hubs to see where we were at. Bingo, they matched up. So the stub, the hub and the height are all the same. HOWEVER, there is one area to be addressed. the -6 stub sticks up about 5mm past the center of the hub. It is going to require a spacer to fill in the area so the washer and nut will tighten down. I am thinking that the one that Patrick Motor sports will do the trick. I think it will be worth trying because I am using Boxster wheels.
Tell me what you think. Attached image(s) |
914GTSTI |
Feb 12 2015, 10:53 PM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Scott. The retainers from my Boxster hubs will not work. The hole pattern is wrong. If you want mine you can have them but stop you order.
Yes the hole is bigger but wrong pattern. I will send you a drawing of the two I have so you can see. It will AM, need to get to the shop. Oh, I have the trailing arm apart for painting and I will recheck the cut I made on the 914-4 retainer,AM. Randy |
Amenson |
Feb 13 2015, 06:59 AM
That's opposite lock!! Group: Members Posts: 645 Joined: 27-May 05 From: Dublin, OH Member No.: 4,154 Region Association: None |
Scott. The retainers from my Boxster hubs will not work. The hole pattern is wrong. If you want mine you can have them but stop you order. Yes the hole is bigger but wrong pattern. I will send you a drawing of the two I have so you can see. It will AM, need to get to the shop. Oh, I have the trailing arm apart for painting and I will recheck the cut I made on the 914-4 retainer,AM. Randy The retainers from CFR are for the 914, just made out of aluminum. He just happened to make the center hole pretty much the same size (larger) than the boxster retainer so it is basically a boxster retainer with the 914 mounting holes. |
Lo-Fi Version | Time is now: 16th May 2024 - 12:47 PM |
