Rear drop link bushing, How to install |
jack20 |
Nov 20 2014, 02:47 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
Anyone have advice on installing new bushings in the rear stabilizer?
SirAndy |
Nov 20 2014, 02:50 PM
Resident German Group: Admin Posts: 41,656 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The bushings usually slide into the droplinks fairly easily.
The hard part is getting the ball pressed into the bushing. I drill a small hole in the center of the bushing to let the air escape, then lube them up and use a c-clamp or similar tool to press the stabilizer ball into the bushing. (IMG:style_emoticons/default/smash.gif) |
jack20 |
Nov 20 2014, 02:55 PM
The bushings usually slide into the droplinks fairly easily. The hard part is getting the ball pressed into the bushing. I drill a small hole in the center of the bushing to let the air escape, then lube them up and use a c-clamp or similar tool to press the stabilizer ball into the bushing. (IMG:style_emoticons/default/smash.gif) I'm having trouble getting the new bushings into the lollipop holder. Any tips there? I tried putting the bushing in boiling water. No help. Tried grease, nothing... |
SirAndy |
Nov 20 2014, 03:06 PM
I'm having trouble getting the new bushings into the lollipop holder. Any tips there? I tried putting the bushing in boiling water. No help. Tried grease, nothing... Hmmm, never had that problem, where did you get the bushings from? (IMG:style_emoticons/default/idea.gif) |
jack20 |
Nov 20 2014, 03:07 PM
I'm having trouble getting the new bushings into the lollipop holder. Any tips there? I tried putting the bushing in boiling water. No help. Tried grease, nothing... Hmmm, never had that problem, where did you get the bushings from? (IMG:style_emoticons/default/idea.gif) Pelican |
Lo-Fi Version | Time is now: 25th May 2024 - 06:06 AM |
