Clutch cable problem. |
ripper911 |
Nov 24 2014, 06:08 PM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
Well... I replaced my clutch cable this afternoon, but It's not tightening up enough. It seems like I have it all the way tightened at the tranny end, and if I screw the clevis end any more I don't think I'll be able to get the pin in.
Did I get the wrong cable? 914.423.401.05 my car is a 74. Have people been seeing a trend of cables not fitting? Any ideas? |
steuspeed |
Nov 24 2014, 06:44 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
I bought a Gemo cable for my 73. I don't have the part order handy. No problems installing and adjusting.
Java2570 |
Nov 24 2014, 06:46 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Same here, Gemo cable from Pelican, no issues on install.
Nov 24 2014, 06:49 PM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Any ideas? Make sure the clutch tube is securely attached to the chassis on both ends and doesn't move or flex. (IMG:style_emoticons/default/idea.gif) |
Nov 24 2014, 06:59 PM
Slip about 1/2" long piece of tubing over the cable between the clevis and the M7 nuts. I'm not sure if the metal (911) clevis is shorter than the plastic (914) one, or what, but it's pretty common to run out of adjustment in a 914.
Several stacked ~M10 nuts can work as well. --DD |
Cap'n Krusty |
Nov 24 2014, 07:08 PM
The metal trunion is substantially shorter than the plastic 914 trunion, which by now has to be pretty rare. It's much longer, however, then the original 911/912 plastic one.
The Cap'n |
ripper911 |
Nov 24 2014, 08:02 PM
I doubt that it is my clutch tube since the old cable was working, it just broke.
I'll try some spacers and such tomorrow. |
Nov 24 2014, 08:10 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You need a hearse already....
bdstone914 |
Nov 24 2014, 08:16 PM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I doubt that it is my clutch tube since the old cable was working, it just broke. I'll try some spacers and such tomorrow. Add another trunion at tans. There was a special long nut that was used to take up the extra slack. I have seen a few and have never seen a part number for it. This is from a 1969 parts catalog. Attached thumbnail(s) |
ripper911 |
Nov 24 2014, 08:33 PM
It's strange that it worked before. The only difference now is the new cable, and that I lost an adjusting nut in the grass. I used an extra heat exchanger flange nut to take up the space of the lost nut temporarily. I don't remember there being anything else on there, but I could be wrong...
Come to think of it, I think I had spacers and such there before my time at AA, I think they did something else to make it work. |
ripper911 |
Nov 24 2014, 08:38 PM
You need a hearse already.... If Ihad the cash, and if it was air-cooled... 1938 Packard Or there is always this one. Needs a little more work. |
Nov 24 2014, 09:07 PM
Packard, as is.....get a new motor, don't change the patina at all.
Or, the Buick...go for a resto funk...I love those front grills. |
ripper911 |
Nov 24 2014, 09:11 PM
Nov 24 2014, 09:16 PM
Type 4.....two of them, maybe three...
Jeffs9146 |
Nov 25 2014, 02:09 PM
It's strange that it worked before. The only difference now is the new cable, and that I lost an adjusting nut in the grass. I used an extra heat exchanger flange nut to take up the space of the lost nut temporarily. I don't remember there being anything else on there, but I could be wrong... Come to think of it, I think I had spacers and such there before my time at AA, I think they did something else to make it work. You can take up some of the length by adjusting the front section of the cable. Remove the trans connection, adjust the front and reattach it then readjust the rear again. |
bandjoey |
Nov 25 2014, 02:28 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Wrapped around the accel cable in the tunnel?
Jeffs9146 |
Nov 25 2014, 02:36 PM
Wrapped around the accel cable in the tunnel? That would make it to short! (IMG:style_emoticons/default/huh.gif) |
ripper911 |
Nov 25 2014, 03:57 PM
I grabbed some nuts and got in in there far enough into it, but now I can play a tune on my clutch cable with my shifter. The good news is that I can change the note with the pedal.
Yeah, I know... I'll undo the pedal end and push it through again. Note to self: 424 160 0712 (the old cable) fits with the metal trunion. |
ripper911 |
Nov 25 2014, 04:33 PM
All I had to do was fix my stupid mistake from last night.
(IMG:style_emoticons/default/alfred.gif) I had run the cable through the large hole in the firewall instead of the clutch tube. It's fine now! (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/laugh.gif) |
pilothyer |
Nov 25 2014, 04:50 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
One thing for sure.....you'll never do that again (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 27th May 2024 - 06:37 PM |
