ripper911
Nov 24 2014, 06:08 PM
Well... I replaced my clutch cable this afternoon, but It's not tightening up enough. It seems like I have it all the way tightened at the tranny end, and if I screw the clevis end any more I don't think I'll be able to get the pin in.
Did I get the wrong cable? 914.423.401.05 my car is a 74.
Have people been seeing a trend of cables not fitting?
Any ideas?
steuspeed
Nov 24 2014, 06:44 PM
I bought a Gemo cable for my 73. I don't have the part order handy. No problems installing and adjusting.
Java2570
Nov 24 2014, 06:46 PM
Same here, Gemo cable from Pelican, no issues on install.
Nov 24 2014, 06:49 PM
QUOTE(ripper911 @ Nov 24 2014, 04:08 PM)
Any ideas?
Make sure the clutch tube is securely attached to the chassis on both ends and doesn't move or flex.
Dave_Darling
Nov 24 2014, 06:59 PM
Slip about 1/2" long piece of tubing over the cable between the clevis and the M7 nuts. I'm not sure if the metal (911) clevis is shorter than the plastic (914) one, or what, but it's pretty common to run out of adjustment in a 914.
Several stacked ~M10 nuts can work as well.
--DD
Cap'n Krusty
Nov 24 2014, 07:08 PM
The metal trunion is substantially shorter than the plastic 914 trunion, which by now has to be pretty rare. It's much longer, however, then the original 911/912 plastic one.
The Cap'n
ripper911
Nov 24 2014, 08:02 PM
I doubt that it is my clutch tube since the old cable was working, it just broke.
I'll try some spacers and such tomorrow.
r_towle
Nov 24 2014, 08:10 PM
You need a hearse already....
bdstone914
Nov 24 2014, 08:16 PM
QUOTE(ripper911 @ Nov 24 2014, 08:02 PM)
Add another trunion at tans. There was a special long nut that was used to take up the extra slack. I have seen a few and have never seen a part number for it. This is from a 1969 parts catalog.
ripper911
Nov 24 2014, 08:33 PM
It's strange that it worked before. The only difference now is the new cable, and that I lost an adjusting nut in the grass. I used an extra heat exchanger flange nut to take up the space of the lost nut temporarily. I don't remember there being anything else on there, but I could be wrong...
Come to think of it, I think I had spacers and such there before my time at AA, I think they did something else to make it work.
ripper911
Nov 24 2014, 08:38 PM
QUOTE(r_towle @ Nov 24 2014, 09:10 PM)
If Ihad the cash, and if it was air-cooled...
1938 PackardOr there is always this one.
Needs a little more work.
r_towle
Nov 24 2014, 09:07 PM
Packard, as is.....get a new motor, don't change the patina at all.
Or, the Buick...go for a resto funk...I love those front grills.
ripper911
Nov 24 2014, 09:11 PM
QUOTE(r_towle @ Nov 24 2014, 10:07 PM)
Packard, as is.....get a new motor.
Type 4?
Flat 6?
r_towle
Nov 24 2014, 09:16 PM
Type 4.....two of them, maybe three...
Jeffs9146
Nov 25 2014, 02:09 PM
QUOTE(ripper911 @ Nov 24 2014, 06:33 PM)
You can take up some of the length by adjusting the front section of the cable.
Remove the trans connection, adjust the front and reattach it then readjust the rear again.
bandjoey
Nov 25 2014, 02:28 PM
Wrapped around the accel cable in the tunnel?
Jeffs9146
Nov 25 2014, 02:36 PM
QUOTE(bandjoey @ Nov 25 2014, 12:28 PM)
That would make it to short!
ripper911
Nov 25 2014, 03:57 PM
I grabbed some nuts and got in in there far enough into it, but now I can play a tune on my clutch cable with my shifter. The good news is that I can change the note with the pedal.
Yeah, I know... I'll undo the pedal end and push it through again.
Note to self: 424 160 0712 (the old cable) fits with the metal trunion.
ripper911
Nov 25 2014, 04:33 PM
All I had to do was fix my stupid mistake from last night.
I had run the cable through the large hole in the firewall instead of the clutch tube. It's fine now!
pilothyer
Nov 25 2014, 04:50 PM
One thing for sure.....you'll never do that again
