Troubleshooting: 2.0 won't stay running |
Nate |
Nov 26 2014, 03:36 PM
Newbie Group: Members Posts: 47 Joined: 21-August 14 From: Southern California Member No.: 17,807 Region Association: Southern California |
Hey everyone! Hope you are all preparing for a nice thanksgiving.
Wanted to see what ideas you guys had about my original FI 2.0 from 73. Some of you may have seen a few other threads of mine but I'll give a little synopsis. I rebuild the motor in my garage. New Pistons and cylinders, all new bearings, lifters. Ground crank and cam. Heads rebuilt by a reputable shop. For the rest of the car. New fuel lines, cleaned and coated fuel tank. New fuel filter. Cleaned and flow matched fuel injectors. Rebuilt distributor. Tuned dwell angle and set static timing. So I've done all of that and the car won't stay running. It'll start and run for 20 seconds with a high idle (approximately 2500 rpm's) and then it will die even if I'm feathering the throttle. I'm looking for ideas as to what and how to troubleshoot the car. IF this car was a person I'd strangle it to relieve my frustration. P.S. I went through the ecu harness and ohm'd everything out and there are no shorts in the wiring and the grounds are solid. I also replaced the throttle position switch and have that set up according to the book and have messed with the idle mixture knob a bit. Anyone have any ideas on where I should go from here? Thanks and I wish everyone a good safe holiday. |
saigon71 |
Nov 26 2014, 04:21 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Have you tested your fuel pump?
gasman |
Nov 26 2014, 04:32 PM
Member Group: Members Posts: 107 Joined: 21-January 08 From: Mooresville, nc Member No.: 8,602 Region Association: South East States |
Got to put a gauge on the fuel system..(fuel rail). Also try replacing the fuel relays.
Nate |
Nov 26 2014, 04:41 PM
I have not bench tested the fuel pump but I can see it pumping fuel through the clear fuel filter while cranking the motor. I will look into the fuel relays. Thanks for the tip. I have not had a chance to check fuel pressure as I don't have the necessary apparatus and haven't built one yet.
saigon71 |
Nov 26 2014, 04:59 PM
I have not bench tested the fuel pump but I can see it pumping fuel through the clear fuel filter while cranking the motor. I will look into the fuel relays. Thanks for the tip. I have not had a chance to check fuel pressure as I don't have the necessary apparatus and haven't built one yet. Fuel pressure test should show if the pump is working properly. I picked up a kit at Harbor Freight for less than $15 (I think) to check fuel pressure. Just pull the bolt out of the drivers side fuel rail and hook up the gauge. Keep us posted on what you find out. |
914_teener |
Nov 26 2014, 05:31 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Find somebody close to help you.
Nate |
Nov 26 2014, 05:34 PM
Good call on a harbor freight fuel pressure gauge. I'll pick one up and let you guys know what I find!
toadman |
Nov 26 2014, 07:56 PM
Member Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
Although they are nearly bullet proof, I had starting problems that I traced to a bad ECU/fuel injection brain. I found it by accident. I was troubleshooting and accidentally touched the ECU and felt a hot spot on the case. Something failed inside and it generated some heat that heated up the outside of the ECU.
boxsterfan |
Nov 27 2014, 12:13 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Cylinder Head Temp Sensor?
Been through the pbanders site? http://members.rennlist.com/pbanders/DJetParts.htm |
Java2570 |
Nov 27 2014, 09:56 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Check out your trigger points in the base of the distributor, maybe swap them out with another set; also make sure the connector is secure and not vibrating loose when the engine is running.
Check the condition of the points plate ground wire in the distributor. |
Luke M |
Nov 27 2014, 10:08 AM
Senior Member Group: Members Posts: 1,370 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I agree check it.. A friend and I spent several hours looking over his engine to finally find a bad sensor.. it was a quick fix once we figured it out.. We never thought about it as it's out of sight out of mind type of thing.. |
pvollma |
Nov 27 2014, 01:46 PM
Member Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region |
I picked up a kit at Harbor Freight for less than $15 (I think) to check fuel pressure. I'm interested in adding a pressure tester to my toolbox. Is this the Harbor Freight pressure tester you referenced? Fuel Injection Pump Tester However, the description states that it does not work with Bosch systems. |
saigon71 |
Nov 27 2014, 08:21 PM
I picked up a kit at Harbor Freight for less than $15 (I think) to check fuel pressure. I'm interested in adding a pressure tester to my toolbox. Is this the Harbor Freight pressure tester you referenced? Fuel Injection Pump Tester However, the description states that it does not work with Bosch systems. Just checked...That's exactly the one I bought. I just used a hose clamp on the fuel rail and used the supplied fittings up to the gauge. It did what I needed it to do. Maybe they are referring to newer Bosch FI systems? |
Nate |
Nov 28 2014, 01:18 AM
Check out your trigger points in the base of the distributor, maybe swap them out with another set; also make sure the connector is secure and not vibrating loose when the engine is running. Check the condition of the points plate ground wire in the distributor. This points plate ground wire that you speak of. Is it a small braided wire type of deal? |
Java2570 |
Nov 28 2014, 06:47 AM
Check out your trigger points in the base of the distributor, maybe swap them out with another set; also make sure the connector is secure and not vibrating loose when the engine is running. Check the condition of the points plate ground wire in the distributor. This points plate ground wire that you speak of. Is it a small braided wire type of deal? Yes, the small braided copper wire is connected to both plates. |
Nate |
Nov 28 2014, 04:18 PM
Okay guys. So, I resoldered the points plate ground wire since that had come off of the top plate. I also verified that the fuel pressure was at approximately 30psi. Still no dice. I'm going to pull the head temp sensor and test that. I'm kind of worried as to what I do if it's bad though since they are so hard to get ahold of for the 1973 2.0L. I guess mine requires the 0 280 130 017 Bosch part number which are near impossible to obtain.
76-914 |
Nov 28 2014, 08:19 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
You can add a resistor to the std temp sensor or install a variable resistor instead.
bandjoey |
Nov 28 2014, 09:03 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Points and condenser or the little electronic gadget that replaces them? Like Pertronix?
There was a thread talking about the screw holding the Pertronicd plate to the distributor was grounding the unit and to cut doen that screw. |
Nate |
Nov 28 2014, 09:05 PM
Alright guys. I've tried everything you have recommended I check. Just finished installing a potentiometer in line with the cylinder head temp sensor and have messed with different ohm values to try to get it to run. This is a 73 and I'm not running the ballast resistor. Could that be the problem?
This car ran 10 years ago. I just rebuilt the motor but didn't change any sensors or electronics aside from rebuilding the distributor with new cap, points, etc. I should also mention that it ran better than this a few weeks ago before I realized the injectors were gummed up and sent them off for cleaning. Any other diagnostics I can perform to get this thing going? It needs to get back on the road and it's so close! |
Nate |
Nov 28 2014, 09:06 PM
Joey. I'm using stock style points and condenser.
Lo-Fi Version | Time is now: 2nd May 2024 - 02:45 AM |
