Troubleshooting: 2.0 won't stay running |
Nate |
Nov 26 2014, 03:36 PM
Newbie Group: Members Posts: 47 Joined: 21-August 14 From: Southern California Member No.: 17,807 Region Association: Southern California |
Hey everyone! Hope you are all preparing for a nice thanksgiving.
Wanted to see what ideas you guys had about my original FI 2.0 from 73. Some of you may have seen a few other threads of mine but I'll give a little synopsis. I rebuild the motor in my garage. New Pistons and cylinders, all new bearings, lifters. Ground crank and cam. Heads rebuilt by a reputable shop. For the rest of the car. New fuel lines, cleaned and coated fuel tank. New fuel filter. Cleaned and flow matched fuel injectors. Rebuilt distributor. Tuned dwell angle and set static timing. So I've done all of that and the car won't stay running. It'll start and run for 20 seconds with a high idle (approximately 2500 rpm's) and then it will die even if I'm feathering the throttle. I'm looking for ideas as to what and how to troubleshoot the car. IF this car was a person I'd strangle it to relieve my frustration. P.S. I went through the ecu harness and ohm'd everything out and there are no shorts in the wiring and the grounds are solid. I also replaced the throttle position switch and have that set up according to the book and have messed with the idle mixture knob a bit. Anyone have any ideas on where I should go from here? Thanks and I wish everyone a good safe holiday. |
Nate |
Nov 28 2014, 11:38 PM
Tried a different ignition switch? Injector to ecu connectors on the right ones? Spark plugs wires going to the right locations? Cracked relay board? Bad/intermittent voltage regulator? Pinched fuel line (is the fuel pump fairly quiet or does it make a bunch of noise....ie sound too loud)? Very tough problem. Sounds like it cranks. Sounds like you got fuel. Sounds like you got spark. Could be a pinched fuel line since I dropped the tank back in. But I don't really think so. I'll check that tomorrow. Connectors are on the right injectors. Plug wires are routed correctly. Relay board looks perfectly fine. Haven't checked the voltage reg but I will. Ive pretty much run out of the big ticket items to check. Even if there is a peripheral item that is malfunctioning it seems like the car should run somewhat. All that I've been able to muster is about 10 seconds of run time and that is after I haven't tried to start it for a while. After that initial 10 second run, it shuts itself off and then all I get is for it to run for a couple seconds and then it shuts off each subsequent time I try to start it. |
boxsterfan |
Nov 29 2014, 12:20 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Tried a different ignition switch? Injector to ecu connectors on the right ones? Spark plugs wires going to the right locations? Cracked relay board? Bad/intermittent voltage regulator? Pinched fuel line (is the fuel pump fairly quiet or does it make a bunch of noise....ie sound too loud)? Very tough problem. Sounds like it cranks. Sounds like you got fuel. Sounds like you got spark. Could be a pinched fuel line since I dropped the tank back in. But I don't really think so. I'll check that tomorrow. Connectors are on the right injectors. Plug wires are routed correctly. Relay board looks perfectly fine. Haven't checked the voltage reg but I will. Ive pretty much run out of the big ticket items to check. Even if there is a peripheral item that is malfunctioning it seems like the car should run somewhat. All that I've been able to muster is about 10 seconds of run time and that is after I haven't tried to start it for a while. After that initial 10 second run, it shuts itself off and then all I get is for it to run for a couple seconds and then it shuts off each subsequent time I try to start it. My car has been on jackstands all fall since a failed fuel pump. I had the tank back in a couple times. One time it ran but wouldn't stop with turning off the key. Eventually degraded to a no-start. In your case, perhaps enough gas is getting through a pinched supply line. Once you start the car though, the suction from the pump closes the supply line completely and there you go. I put in the 30R9 fuel hose. Stuff loves to bind up. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:11 PM |
