FS or TRADE: 103mm JE P/Cs and 2.0L block, brand new JE P/Cs and GA series block |
JoeDees |
Nov 28 2014, 10:56 AM
Senior Member Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
Decided not to build a big engine so I'm selling this stuff I picked up in a big parts lot. The 103mm JE pistons and cylinders are brand new but missing wrist pins and have minor dings on head side of one of the cylinders. $400
I also have a 2.0L block with innards and pistons/rods, fan, oil cooler with a GA serial number for $250. Located in Norman, OK. Will sell the lot for $500 together or trade the Ps and Cs for brand new 1.7L 90mm domed P/C set. Link to my Flickr album with more pics: https://www.flickr.com/photos/123732647@N02...57649500001902/ Attached thumbnail(s) |
JoeDees |
Nov 28 2014, 10:57 AM
I should mention that I prefer cash and would rather not ship, but arrangements could be made with a good offer.
JoeDees |
Nov 30 2014, 03:51 PM
Had a request for more pics.
JoeDees |
Nov 30 2014, 03:53 PM
More Pics
JoeDees |
Dec 4 2014, 08:56 AM
Bump
Any offers? |
DRPHIL914 |
Dec 4 2014, 10:14 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Bump Any offers? what displacement would these result in when put with a 2.0 motor?i have a '75 2.0L stock motor that will need rebuilding and have been considering my options for staying with F,I but getting a bit more HP. also what additional work would be required? since the heads would be worked any way what modifications wold be required to the heads to fit these? Phil |
VWTortuga336 |
Dec 4 2014, 11:58 AM
Member Group: Members Posts: 285 Joined: 5-October 14 From: Kansas City, Missouri Member No.: 17,979 Region Association: None |
Assuming your 2.0L has the stock 71mm stroke crank, you would be at 2366cc. I would think the case will have to be machined to accommodate the larger cylinder OD and the heads will have to be flycut to the larger diameter as well.
JoeDees |
Dec 4 2014, 12:33 PM
Yeah, it would make a 2366cc with the 71mm stroke. As far as I know machining the case and heads is necessary, and the heads may need bigger valves. I've also read that going dual carbs is helpful to attaining maximum hp and performance.
koozy |
Dec 6 2014, 04:51 PM
Senior Member Group: Members Posts: 648 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
Sending PM on the P&C set
vinniedatorch |
Dec 7 2014, 10:53 AM
Newbie Group: Members Posts: 40 Joined: 12-January 13 From: Lakewood Ca. Member No.: 15,358 Region Association: Southern California |
next in line on the entire package (IMG:style_emoticons/default/piratenanner.gif)
vinniedatorch |
Dec 7 2014, 10:55 AM
JoeDees |
Dec 14 2014, 01:14 PM
Try and bump this again. Let's work out a deal. Army says I need to move soon and I need to pare down the collection. I also want some money to put into my car. haha
JoeDees |
Dec 18 2014, 02:45 PM
Pistons and cylinders are sold, and engine block may be pending.
Lo-Fi Version | Time is now: 6th May 2024 - 01:49 AM |
