Racing seats |
Racing seats |
GaroldShaffer |
Nov 29 2014, 09:57 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
So the old racecar (that I sold a few years ago) had a Sparco Evo II seat was bolted directly to the floor and it fit my big (IMG:style_emoticons/default/bootyshake.gif) just fine. My street / AX car I have the GTS Classics LeMans seat. Works great, but the head rest is to thick and forces my head forward when I have my helmet on. I remove the heard rest when Axing.
The new 73 track day /AX car currently has just a stock seat in it. I would like to find something like the old Evo II seat I had, but I want to be able to use the stock seat tracks. I will have a co-driver and need to be able adjust the seat. So what are you guys using? |
Randal |
Nov 29 2014, 10:18 PM
So the old racecar (that I sold a few years ago) had a Sparco Evo II seat was bolted directly to the floor and it fit my big (IMG:style_emoticons/default/bootyshake.gif) just fine. My street / AX car I have the GTS Classics LeMans seat. Works great, but the head rest is to thick and forces my head forward when I have my helmet on. I remove the heard rest when Axing. The new 73 track day /AX car currently has just a stock seat in it. I would like to find something like the old Evo II seat I had, but I want to be able to use the stock seat tracks. I will have a co-driver and need to be able adjust the seat. So what are you guys using? For autoxing Kirkey is my choice. Keeps you from moving around. With 5 or 6 point belts even better. For the street, nah. |
GaroldShaffer |
Nov 29 2014, 10:32 PM
So the old racecar (that I sold a few years ago) had a Sparco Evo II seat was bolted directly to the floor and it fit my big (IMG:style_emoticons/default/bootyshake.gif) just fine. My street / AX car I have the GTS Classics LeMans seat. Works great, but the head rest is to thick and forces my head forward when I have my helmet on. I remove the heard rest when Axing. The new 73 track day /AX car currently has just a stock seat in it. I would like to find something like the old Evo II seat I had, but I want to be able to use the stock seat tracks. I will have a co-driver and need to be able adjust the seat. So what are you guys using? For autoxing Kirkey is my choice. Keeps you from moving around. With 5 or 6 point belts even better. For the street, nah. Is your seat adjustable? Is it mounted to the stock seat rails? |
J P Stein |
Nov 30 2014, 09:42 AM
Sure, just remove the seat mounted rails from your stock seat & bolt it to your Kirkey.
Randal |
Nov 30 2014, 11:35 AM
So the old racecar (that I sold a few years ago) had a Sparco Evo II seat was bolted directly to the floor and it fit my big (IMG:style_emoticons/default/bootyshake.gif) just fine. My street / AX car I have the GTS Classics LeMans seat. Works great, but the head rest is to thick and forces my head forward when I have my helmet on. I remove the heard rest when Axing. The new 73 track day /AX car currently has just a stock seat in it. I would like to find something like the old Evo II seat I had, but I want to be able to use the stock seat tracks. I will have a co-driver and need to be able adjust the seat. So what are you guys using? For autoxing Kirkey is my choice. Keeps you from moving around. With 5 or 6 point belts even better. For the street, nah. Is your seat adjustable? Is it mounted to the stock seat rails? Mine is bolted to the floor as I wanted it as low as possible. But you could mount it to the standard seat carrier, just a bit of fabrication. Also I think Kirkey has a movable mount. |
GaroldShaffer |
Nov 30 2014, 04:10 PM
What model Kirkey seat did you use?
Randal |
Nov 30 2014, 04:34 PM
What model Kirkey seat did you use? Intermediate road racing seat: http://www.summitracing.com/parts/kir-4750...NEsgaAqrZ8P8HAQ They also sell a cover. |
Seabird |
Dec 1 2014, 01:27 PM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
IF you go with the Aluminum Seat option you might want to consider some of those foam pads like Pegasus sells.
If you hunt the web you can find some of the airplane sites that sell it. About half the price but without the protective coating. Feels real confie on the butt. M |
Wegeng_Haus |
Dec 10 2014, 08:29 AM
Newbie Group: Members Posts: 38 Joined: 10-December 11 From: Champaign Illinois Member No.: 13,881 Region Association: Upper MidWest |
For thee Sparco seat, I bolted the stock inboard seat rail to the seat, w/3/8" spacers. Then bolted a strip of 3/8" sheet aluminum to the outboard side of the seat (1"-2" wide, can't remember). By setting the seat in the car and measuring, observing and marking withe old Sharpy, I was able to locate and drill holes in the aluminum to mount the stock seat rail, oblonging the holes slightly for adjustment. Lastly, by mounting the stock seat rail to the aluminum bar, with the bolts slightly snug and sliding the seat onto the stock seat slider and moving the seat up and back, the outboard seat rail sought its proper position. Once more out of the car to torque the mounting bolts and presto! It works great with no problems. (Note: I used the aluminum bar on the doorside rail, because this mod does move the seat over a smidge and moving to the tunnel side suited me better. You could just as easily move towards the door side).
Lo-Fi Version | Time is now: 28th April 2024 - 12:13 PM |
