"Front main" seal on a /6, Any tips, traps or suggestions? |
BigD9146gt |
Feb 2 2005, 09:46 PM
OCD member Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand |
OT, hey guys, i'm new at this, whats DWD?... Besides my startup company (DonWelchDesign)
J P Stein |
Feb 3 2005, 02:43 AM
http://www.914world.com/bbs2/index.php?act=...699&hl=dwd&st=0 About half way down the first page. |
larryM |
Mar 2 2005, 04:51 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
I fought this last year; pulled the engine; leak indeed turned out to be the gasket on the intermediate cover |
Gint |
Mar 2 2005, 10:22 PM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Can someone explain this to me. #8 main bearing o-ring? O-ring? Huh? Got pics? |
ClayPerrine |
Mar 2 2005, 10:29 PM
Life's been good to me so far..... Group: Admin Posts: 15,436 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Here you go.... #27 is the O-ring that goes around the outside of the bearing (#25)
Attached thumbnail(s) |
JoeSharp |
Mar 2 2005, 10:57 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Rusty: It's nice to know that i"m not the only one with DWD.
(IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) Joe |
Gint |
Mar 2 2005, 11:07 PM
Thanks Clay. And just how does one go about replacing that bad boy?
TimT |
Mar 2 2005, 11:29 PM
You split the case depending what year engine you have there are different o-rings available, I think for the 2.7 and later the improved the o-ring has a slightly larger diameter (thicker) rubber, which can be used on the earlier nose bearings...but not vice versa |
Gint |
Mar 2 2005, 11:33 PM
Thanks Tim. That's exactly the answer I didn't want to hear. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Cap'n Krusty |
Mar 2 2005, 11:47 PM
BTW, there's NO sealant in there, just the case, the bearing, and the o- ring. Sealant prevents the seal between the o-ring and the metal, and it'll leak. The Cap'n
Gint |
Mar 2 2005, 11:52 PM
914efi |
Mar 3 2005, 05:09 PM
Member Group: Members Posts: 140 Joined: 14-June 04 From: Westport,MA Member No.: 2,204 Region Association: None |
I have this leak also. You can support the engine, remove the front mount and sheetmetal and run the engine while observing to determine where the leak is coming from(remove the fan pulley also). You can replace the countershaft cover seal at his point if it needs it. I assume you can also replace the seal on the crank, but I did not attempt once I could see that the oil was coming from around the bearing and not the seal.
I have tried many things to fix, but the most successful was sealing the front motor mount to the engine and putting a drain in the bottom. I then collect the oil in a section of hose with a plug that I can remove to drain it. The oil still gets through the top of the engine area, but I don't feel like tearing it apart to fix this. |
ArtechnikA |
Mar 3 2005, 06:32 PM
if it's any consolation, LB, the 911 leaks there too, and the engine will be getting a total rehab RSN...
J P Stein |
Mar 3 2005, 07:14 PM
Well, Capt'n, some folks run a bead of case sealer around the
Bearing *away* from the the O ring....pick a guru, cause there's conflicting advice. I chose not to & slathered silicome grease all over and it leaks. Same with the verticle chain case gasket. No gasket sealent and one leaks, the other don't. Shit happens, eh? |
Lo-Fi Version | Time is now: 4th May 2024 - 04:03 PM |
