> Gas Tank Nylon Washers, NLA - but anyone have the I.D. and O.D. measurements
boxsterfan
post Dec 2 2014, 07:30 PM
914's are kewl
As is mentioned here in many threads, the nylon washers for the supply and return lines for the gas tank are NLA. I'm hoping to find some time over the holidays to get my 914 running again, but need to come up with:
1. Copper sealing washers - supply side (available at buggyhaus and others). Part#: 111209139
2. Copper sealing washer - return side (??? part#, was there one)?. AA shows this part# 311201235A
3. Nylon washers? I don't see these in the exploded parts diagram at AA but that doesn't mean anything.
I feel like buying a box of 5,000 of the copper washers and distributing them freely to all 914World.com members given the PITA this project has been....but then I looked up the price of copper. :-)
913B
post Dec 2 2014, 08:01 PM
I bought mines from Robert.
http://www.914world.com/bbs2/index.php?showtopic=110158
boxsterfan
post Dec 2 2014, 08:11 PM
914's are kewl
Saw this link in another thread. What's the right size?
http://www.specialtauto.com/delorean-parts...are-metric.html
Loads of metric copper washers.
bdstone914
post Dec 2 2014, 11:29 PM
bdstone914
I would not use copper crush washers. You may strip the threads on the aluminum nuts trying to get than tight enough to seal. Get the fiber ones from Robert. They work. Late tanks have different size nipples.
Mikey914
post Dec 2 2014, 11:41 PM
The rubber man
Get me the Dims I'll bring them in and put them in the hardware section for cheap. I want to compile a section on the website of hardware that's a pain to find. That way, if you have something you are already getting it's easy to just add in the parts for hardware store prices.
ChrisFoley
post Dec 3 2014, 07:44 AM
I am Tangerine Racing
I also have them, always 1 included with the strainer screens I sell, just not listed separately on my website yet.
I haven't found much need to replace the one on the return fitting though.
saigon71
post Dec 3 2014, 07:58 AM
I took the nipples with me to the local ACE hardware store. I found one fiber washer that fit perfectly, another with the correct ID that I just trimmed down with scissors to fit. Worked great.
I don't remember using any copper washers.
boxsterfan
post Dec 3 2014, 12:56 PM
914's are kewl
QUOTE(Racer Chris @ Dec 3 2014, 05:44 AM) *
Hi Chris,
Yeah, I buggered the one up that I ordered from you (with the new fuel sock). I've got another order I need to put together with you, so I guess I'll just add those in then.
boxsterfan
post Dec 3 2014, 12:57 PM
914's are kewl
I think this is why I am so confused. Correct me if I am wrong, but it sounds like since the nylon washers were hard to find that most people simply went the copper crush washer route?
Mikey914
post Dec 3 2014, 06:53 PM
The rubber man
That's what I'm understating. No problem getting or making them in the 1000's just need solid dims.
914Sixer
post Dec 3 2014, 06:56 PM
I guess I am confused, I have never seen any nylon washers on nipple fittings. They have always been fiber and copper washers.
boxsterfan
post Dec 3 2014, 07:06 PM
914's are kewl
QUOTE(914Sixer @ Dec 3 2014, 04:56 PM) *
OK, my mistake. They were fiber washers. Regardless sounds like people just converted to copper crush washers when the fiber washers ran out.
My gas tank saga continues....
puffinator
post Dec 3 2014, 08:01 PM
QUOTE(boxsterfan @ Dec 3 2014, 08:06 PM) *
Tangerine Racing. $0.95 each. See Chris' post above
patssle
post Dec 3 2014, 09:18 PM
I had gas tank outlet frustrations too. My new fiber washers leaked.
New metric to AN fittings solved all my problems! http://www.914world.com/bbs2/index.php?sho...=241493&hl=
boxsterfan
post Dec 3 2014, 09:54 PM
914's are kewl
QUOTE(patssle @ Dec 3 2014, 07:18 PM) *
Did you go without a fuel sock? Personally, I don't think its a big deal to go without the sock especially if you get your fuel filter mounted where you can get at it and change it regularly (cheap insurance).
After all my troubles, this seems like the way to go. Also, which 90 degree AN to hose barb did you get? I'm running FI so I'll have to get the return side also.
boxsterfan
post Dec 3 2014, 11:54 PM
914's are kewl
This looks like a good candidate.
http://autoplicity.com/products/1318586-xr...on_hoseend.aspx
I wonder if it comes with a rubber sealing o-ring also?
CptTripps
post Dec 4 2014, 12:35 PM
:: Punch and Pie ::
I used copper crush washers, but now I'm thinking I may need to go back in to switch them out for the nylon ones.
Just another thing on the list of shit I have to re-do before I'm road worthy.
patssle
post Dec 4 2014, 05:30 PM
No I don't have the sock...but I have a fuel filter so I'm okay with it. That 45 degree one can work - just check the hose barb dimensions vs. whatever size fuel line you're running.
- Lo-Fi Version Time is now: 30th July 2025 - 02:03 PM
