Drill Bit Recommendation, What do you guys recommend |
warrenoliver |
Dec 4 2014, 09:46 PM
Member Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
With Christmas coming, I would like to get a good set of drill bits. I don't need specialty bits, just regular old drill bits for drilling metal, usually less than 1/2" thickness. I would like to get a set from 1/16" - 1/2" but with a 3/8" shank to fit my cordless drill. What brand/kind of bits do you recommend? I see all types with titanium, chromium, HSS, black oxide, etc. I'm looking for a good reliable set that doesn't dull the first time I use it.
What have you had good luck with? Thanks. Warrrenoliver |
76-914 |
Dec 4 2014, 09:59 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Go to some machinist supply online e.g. ENCO and buy the most expensive bits you can afford. I like cobalt but they are brittle and don't like side loads. If you buy good bits treat them right.
timmaria |
Dec 4 2014, 10:42 PM
Newbie Group: Members Posts: 14 Joined: 13-August 14 From: Fresno, Ca Member No.: 17,773 Region Association: Central California |
You can find high quality bits at swap meets and flea markets really cheap.
GermermanCarGuy |
Dec 5 2014, 09:19 AM
GermanCarGuy Group: Members Posts: 81 Joined: 13-May 14 From: Rapid City, SD Member No.: 17,346 Region Association: Upper MidWest |
Unless you're a fab or metal shop, you don't need to waste the expense by buying the most expensive bits around. When fabricating my rotisserie, I went through seven 1/2" bits before asking a metal shop what I was doing wrong.
You can use any standard shaped metal cutting tip, Carbide or Titanium for Hard metals. I prefer Kobalt or Dewalt. Decent quality and can be had at most hardware stores. I'd recommend adding Drill Doctor Drill Bit Sharpener to your tool box (you won't regret this investment). Add a good cutting oil or 80W to your tool bench. When drilling metal from a Drill Press, use the slowest speed possible, especially on thicker materials, oil often with even pressure. On sheet metal, use a punch to mark your start location to prevent wandering, then drill straight through (parallel to the metal). As a side note. Wood and concrete bits are shaped differently and can't be sharpened using a Drill Doctor. The moderate to higher speed for these applications is better. Hope this helps. Rob |
URY914 |
Dec 5 2014, 09:44 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,563 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Good bits are only half the job.
As said above, my Drill Doctor has paid for itself over and over. Add a bottle of cutting oil and you are a drilling machine. |
Cap'n Krusty |
Dec 5 2014, 10:23 AM
"drill straight through (parallel to the metal)." ? Most of us prefer to drill perpendicular to the metal. More effective, as it puts the hole in a useful position, and the drill bit works a lot better ...
The Cap'n |
cary |
Dec 5 2014, 11:12 AM
Ditto on the cutting oil.
I even use cutting oil on the cheezy HF bits I use for pilot holes for the spot weld cutter. They drill three times as fast and last 10 times as long. |
eric9144 |
Dec 5 2014, 12:08 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
I'd recommend adding Drill Doctor Drill Bit Sharpener to your tool box. (IMG:style_emoticons/default/agree.gif) That makes a remarkably big difference |
GermermanCarGuy |
Dec 5 2014, 01:32 PM
Mueller |
Dec 5 2014, 01:52 PM
For thin sheet metal don't discount unibit/step drills , very versatile
The "real" brand is pricey, I've had decent luck with the HF and other brands for occasional jobs. |
relentless |
Dec 5 2014, 02:29 PM
Member Group: Members Posts: 350 Joined: 1-April 07 From: Oregon Member No.: 7,636 |
After growing tired of replacing the el-cheapo 'titanium coated' drill bits I switched to Hansen HSS. You get what you pay for...
bandjoey |
Dec 5 2014, 02:35 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Thanks for the drill info. What about drill speed? Cordless ranges from 200-1500rpm appx. And cord drills 2000+.
So we buy great drill bits and burn them up right away. Advice here? |
Jeff Hail |
Dec 5 2014, 02:58 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
IRWIN fractional HSS Co5 bits are great. They are actually made by a well known tool company. Bargain for the quality. When it comes time to sharpen them they are as good as a new bit if done correctly.
The cheaper ones sold at Lowes are not the same. Hanson is next on quality but higher priced. Hanson makes bits for other companies. Hint. |
johnhora |
Dec 5 2014, 03:28 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
I found this works best on all the various brands of drill bits I have ever purchased over the years...
patience noun 1. the capacity to accept or tolerate delay, trouble, or suffering without getting angry or upset. |
roblav1 |
Dec 5 2014, 05:08 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Use Cobalt and watch the speed. Each bit requires its own speed - the larger the slower RPM.
aircooledtechguy |
Dec 5 2014, 05:14 PM
One word:
COBALT Anything else pales in comparison. The Drill Dr will pay for itself in short order. |
Matt Romanowski |
Dec 5 2014, 07:46 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Carbide is the best material, followed by cobalt, then HSS. I never found the coating to make a difference unless the bits were run in a CNC with the speeds and feeds calculated and followed.
I would suggest a set of cobalt from someone like Enco. Buy what you can afford and you'll get something pretty good. |
saigon71 |
Dec 6 2014, 07:26 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I used a set very similar to this for the restoration on my car. They were heavily used drilling out spot welds and fabrication new parts out of sheet metal.
It's a great set for the money. As others have said, longevity depends largely on using them with the right speed and lubrication. http://www.lowes.com/pd_71226-70-DW1263_0_...&facetInfo= |
veekry9 |
Dec 6 2014, 10:04 AM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
"drill straight through (parallel to the metal)." ? Most of us prefer to drill perpendicular to the metal. More effective, as it puts the hole in a useful position, and the drill bit works a lot better ... The Cap'n (IMG:style_emoticons/default/lol-2.gif) The average farm hand learns to sharpen a drill bit at the age of 8. look it up and practice.Takes 40 secs. |
Bleyseng |
Dec 6 2014, 11:46 AM
Use Cobalt and watch the speed. Each bit requires its own speed - the larger the slower RPM. Cobalt!!! (IMG:style_emoticons/default/piratenanner.gif) and not the shitty ones at Lowe's. |
Lo-Fi Version | Time is now: 14th May 2024 - 02:35 PM |
