| rosenfe |
Dec 7 2014, 06:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 565 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
when i accelerate and take foot off gas ,i get backfire sound -or similar to that.its not loud,but noticeable.any ideas of what to check.these cars have backfire valve,but im not sure how that works.car runs strong,just adjusted valves.someone on 912e forum suggested exhaust system gaskets,but im not sure if they were referring to gasket at headers or muffler.any ideas?
| rick 918-S |
Dec 7 2014, 06:29 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,287 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Is it back firing or popping from an exhaust leak?
| Mikey914 |
Dec 7 2014, 06:30 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,782 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Exhaust leak
| rosenfe |
Dec 7 2014, 06:41 PM
well the responses suggest exhaust leak.any suggestions as to how to find it?
| rosenfe |
Dec 7 2014, 06:44 PM
more of a popping sound,can i continue to drive it until i find leak or can i burn a valve etc
| pisces914 |
Dec 7 2014, 07:01 PM
Member ![]() ![]() Group: Members Posts: 62 Joined: 27-April 04 From: seattle, wa Member No.: 1,988 |
| patssle |
Dec 7 2014, 07:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Look for carbon blowout - any darkened areas around gaskets and such.
| roblav1 |
Dec 7 2014, 07:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Yup... exhaust leak.
| dknechtly |
Dec 8 2014, 09:29 AM
Yellow 914 ![]() ![]() Group: Members Posts: 71 Joined: 11-April 03 From: Wylie, TX Member No.: 560 Region Association: None |
If you have a two nipple vacuum advance, check that it is good. One of them helps pull back on deceleration.
| stownsen914 |
Dec 8 2014, 10:45 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,015 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Or you already have a burned valve (or not seating properly). The exact symptom I had years ago on my 914 2.0. When I pulled it apart there was a burned valve ...
Check the exhaust leaks first obviously since that's external. You'll hear different methods for doing this, but my favorite is probing around with a length of fuel hose (or other similar sized hose), one end near (but not too near!) your ear, and the other probing around where you think there may be leaks. You'll hear a very audible poofing sound through the hose when you get near a leak. Scott |
| rosenfe |
Dec 8 2014, 11:53 AM
noise had gotten louder after adjusting valves.they were definitely tight.im hoping for exhaust leak.heads were recently doen.i dont want to think about burned valve.
| rosenfe |
Dec 8 2014, 12:43 PM
would a bad deceleration valve cause this problem?
Lo-Fi Version | Time is now: 19th June 2026 - 07:16 AM |
