Full Version: 912e mild backfire on deceleration
rosenfe
when i accelerate and take foot off gas ,i get backfire sound -or similar to that.its not loud,but noticeable.any ideas of what to check.these cars have backfire valve,but im not sure how that works.car runs strong,just adjusted valves.someone on 912e forum suggested exhaust system gaskets,but im not sure if they were referring to gasket at headers or muffler.any ideas?
rick 918-S
Is it back firing or popping from an exhaust leak?
Mikey914
Exhaust leak
rosenfe
well the responses suggest exhaust leak.any suggestions as to how to find it?
rosenfe
more of a popping sound,can i continue to drive it until i find leak or can i burn a valve etc
pisces914
QUOTE(rosenfe @ Dec 7 2014, 04:41 PM) *
take a look at all of the connection points/gaskets - then look at the muffler itself for any holes, especially if you see seams and welds
hope this helps
brad
patssle
Look for carbon blowout - any darkened areas around gaskets and such.
roblav1
Yup... exhaust leak.
dknechtly
If you have a two nipple vacuum advance, check that it is good. One of them helps pull back on deceleration.
stownsen914
Or you already have a burned valve (or not seating properly). The exact symptom I had years ago on my 914 2.0. When I pulled it apart there was a burned valve ...
Check the exhaust leaks first obviously since that's external. You'll hear different methods for doing this, but my favorite is probing around with a length of fuel hose (or other similar sized hose), one end near (but not too near!) your ear, and the other probing around where you think there may be leaks. You'll hear a very audible poofing sound through the hose when you get near a leak.
Scott
rosenfe
noise had gotten louder after adjusting valves.they were definitely tight.im hoping for exhaust leak.heads were recently doen.i dont want to think about burned valve.
rosenfe
would a bad deceleration valve cause this problem?
