FS 914-6 Flyweel/Clutch/Pressure Plate/throw out bearing, Fits 2.0 - 2.7 |
JStroud |
Dec 7 2014, 07:30 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Bought this flywheel new from Maddog when I put the 2.7 in my car, less then 500 miles since new. Sachs clutch,pressure plate, and throw out bearing, only 500 miles since new.
Flywheel, clutch and pressure plate balanced at machine shop prior to installing the 2.7, so less than 500 miles. Complete package for your -6 conversion $625.00 shipped Cont. US |
JStroud |
Dec 10 2014, 08:07 PM
Still available
type47 |
Dec 11 2014, 06:53 AM
So did Maddog buy the flywheel new? (the flywheel has not been machined or surfaced since new?). Is there a normal "marking" on the surface of the flywheel that the clutch disc touches? that is, it sorta looks like a pattern I found/observed where the disc was too small/not correct disc for the clutch set-up and didn't touch the whole surface of the flywheel. I'm not saying this is the case here, I'm sure that the parts are all correct here.
JStroud |
Dec 11 2014, 09:52 AM
So did Maddog buy the flywheel new? (the flywheel has not been machined or surfaced since new?). Is there a normal "marking" on the surface of the flywheel that the clutch disc touches? that is, it sorta looks like a pattern I found/observed where the disc was too small/not correct disc for the clutch set-up and didn't touch the whole surface of the flywheel. I'm not saying this is the case here, I'm sure that the parts are all correct here. I bought the flywheel new from Maddog Motorsport, a member vendor here. The clutch and pressure plate was new from EBS racing, it's a Sachs 215 mm. Had the Flywheel and clutch pkg balance at my machine shop, not surfaced. Install in my 2.7, drove from Sacramento to WCR, then drove to Santa Cruz where it failed a tensioner, towed it home and pulled the motor. So that's how many miles I put on the set up...less than 500. That's all I know. Had to edit this, guess I'm getting old, with the questions I looked up my records, forgot I sold the other clutch and pressure plate with the 2056, bought a new clutch, pressure plate and throw out bearing. Found the throw out bearing, it's included with the package now, so the clutch package and flywheel were both NEW when installed with the 2.7. Paid $450 for the flywheel and $350 for the clutch pkg plus balancing so still a good deal. Sorry for any confusion. |
JStroud |
Dec 11 2014, 01:28 PM
Sold..
Lo-Fi Version | Time is now: 18th May 2024 - 09:18 PM |
