engine tin, yep, made it myself |
worn |
Dec 10 2014, 12:07 PM
can't remember Group: Members Posts: 3,155 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Well, I have tried to make as many things as I can. I caved for the engine mount and got something real nice from RJ. But I had the old 4 cylinder tin and some of the original 3.2 six tin that came with the motor. Here is the motor as it is now (ugly when it was shipped).
So I have the inside, and I have the outside. Plus, I have some of the pieces. How hard could it be? Turns out - pretty durn hard without a pattern. I started with some of the 911 parts matching them to the back transmission tin curves. Then I pulled out a sheet of steel and started on the engine pulley/fan side. The stuff is really fiddly. Making the broad curves was easy. I am not super at shrinking so I cheat in some places by cutting and welding. This next photo shows a trial fit. Welding on the nuts and making everything fit and flat took a couple weekends (not full time). My son's early X-mas gift is in the background. The inside now fits the engine screwed on and the outside fits this. I still have to finish the 911 ebrakes with both butterfly halves. And do the large seal etc. The tranny is rebuilt, and I would say that the time/effort and the tranny rebuild was similar in difficulty to the sheet metal work. But I am not quite as, I think he says crude, as Dr Evil, so I wash everything. If you see his video I would be the guy with all of the gears in a row. |
Lo-Fi Version | Time is now: 14th May 2024 - 10:55 PM |
