2 Pages V < 1 2
> firewall cutouts for 6, I would like to see what you used for the cover
post Dec 12 2014, 12:20 PM
Post #21
Resident German
QUOTE(Mark Henry @ Dec 12 2014, 07:16 AM) *
And Andy how did you get the alt out? Do you have a 2 piece shroud?
Yes, two piece shroud:
patssle
post Dec 12 2014, 12:27 PM
Post #22
Don't need a hole to replace the belt. Here's my trick!
Mark Henry
post Dec 12 2014, 02:06 PM
Post #23
that's what I do!
QUOTE(patssle @ Dec 12 2014, 01:27 PM) *
Wouldn't work for me, I'll have to get a different pulley and I don't know what the hex key is for...
Elliot Cannon
post Dec 12 2014, 02:16 PM
Post #24
Group: Retired Members
If you have a large access hole in a fire wall, shouldn't it be steel rather than aluminum? Wouldn't steel be safer? Maybe I just worry too much. (IMG:style_emoticons/default/biggrin.gif)
ClayPerrine
post Dec 12 2014, 03:15 PM
Post #25
I am going to say this again:
What part of the word FIREWALL do you not understand?????
Cutting a hole in a firewall is a good way to get badly burned if you have an engine fire. Betty and I were in her car when the engine caught fire. The firewall gave us time to get the car pulled over and to get out of the car. It was very bad. If we had a hole in the firewall, the flames would have been in the car with us at 65 mph. That would have been even worse.
No matter how convenient, don't cut a hole in something called a FIREWALL!!!
pcar916
post Dec 12 2014, 03:36 PM
Post #26
Is that a Lola?
QUOTE(Elliot Cannon @ Dec 12 2014, 02:16 PM) *
Steel only for me. Clay brings up a good point though.
There ain't no fire gettin' into mine. Dual seals against that and the cover has a very large overlap.
Cairo94507
post Dec 12 2014, 03:59 PM
Post #27
Michael
No firewall access hole in my Six. Decided.
patssle
post Dec 12 2014, 04:05 PM
Post #28
QUOTE(Mark Henry @ Dec 12 2014, 12:06 PM) *
Hex holds the alternator shaft. Instead of the special $30 alternator pulley wrench.
wndsrfr
post Dec 12 2014, 04:40 PM
Post #29
QUOTE(MJHanna @ Dec 11 2014, 06:47 PM) *
looking for ideas. Mine is cut but it not large enough to be useful. So I'm going to enlarge it and would like to see others solutions.
Here's the first class job that Josh did on Kermee.....
pcar916
post Dec 12 2014, 06:39 PM
Post #30
Is that a Lola?
Wndsrfr, I'm afraid the plexiglass/lucite cover isn't really fireproof enough to keep you safe... might want to rethink that material.
patssle
post Dec 12 2014, 10:55 PM
Post #31
Per firewall...if Porsche put a hole for the Boxster I'm sure the 914 can be done safely if one really wants a hole. With the proper material of course.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 22nd September 2026 - 05:09 AM
