For Sale 914 engine complete, 1971 cc engine |
cali914 |
Dec 12 2014, 12:54 AM
cali914 Group: Members Posts: 447 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
(IMG:style_emoticons/default/biggrin.gif) 1971cc Price drop 2500.00 engine only has 10k on it.
Type IV case line bored, shuffle pinned, drilled and tapped oil passages ( work done by RIMCO ) High volume oil pump 914 2.0 crank machined to rabbit journals. 71mm stroke Rabbit rods CIMA 94mm flat top pistons Mahle 94mm barrels with spacers Webcam 914 stock profile Webcam flat tappet lifters autocraft chromoly pushrods rocker arms with ball end adjusters from CB performance Ported 1.8L heads Sodium filled exhaust valves Lightened flywheel Mallory unilite optical distributor Nology Coil and capacitive wires MSD rev limiter Dellorto 40mm DRLA carbs with anular discharge conversion Sachs 911S aluminum pressure plate and clutch disk |
hblyle |
Dec 18 2014, 04:03 PM
Member Group: Members Posts: 64 Joined: 23-May 11 From: Huntington Beach Member No.: 13,110 Region Association: Southern California |
Where are you located?
MikeInMunich |
Jan 3 2015, 03:54 PM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Was this sold?
forrestkhaag |
Jan 3 2015, 04:22 PM
Not sure if this 1.7 has sold but I am going to sell my 1.7 bone stock fine running 1971 engine &FI thereon and clutch assembly after I create several films of it running at various rpm ranges. Any interest for pickup in Laguna Beach,Ca?
cali914 |
Jan 3 2015, 11:31 PM
Berkeley California
sean_v8_914 |
Jan 8 2015, 11:40 AM
1971cc is the displacement of a 2.0
the 1.7 is also smaller than 1.7. i think its 1641cc ...and a free bump |
cali914 |
Jan 9 2015, 12:34 AM
sean_v8_914 |
Jan 16 2015, 03:07 AM
did this 2.0 sell?
forrestkhaag |
Jan 16 2015, 09:37 AM
Lo-Fi Version | Time is now: 25th April 2024 - 06:32 PM |
