1971cc Price drop 2500.00 engine only has 10k on it.
Type IV case line bored, shuffle pinned, drilled and tapped oil passages ( work done by RIMCO )
High volume oil pump
914 2.0 crank machined to rabbit journals. 71mm stroke
Rabbit rods
CIMA 94mm flat top pistons
Mahle 94mm barrels with spacers
Webcam 914 stock profile
Webcam flat tappet lifters
autocraft chromoly pushrods
rocker arms with ball end adjusters from CB performance
Ported 1.8L heads
Sodium filled exhaust valves
Lightened flywheel
Mallory unilite optical distributor
Nology Coil and capacitive wires
MSD rev limiter
Dellorto 40mm DRLA carbs with anular discharge conversion
Sachs 911S aluminum pressure plate and clutch disk
