> Subaru conversion question, What transmission?
post Dec 12 2014, 04:17 PM
914-6 GT in waiting
The only thing I know about suby transmissions is that I want one for my eg33 conversion. What model should I buy? What should I expect to pay, Where should I look? Blah, blah, blah.
Thanks in advance!
Replies(1 - 10)
mgp4591
post Dec 12 2014, 04:30 PM
I'm using an automatic, but then I'm kinda strange... (IMG:style_emoticons/default/blink.gif)
JRust
post Dec 12 2014, 04:37 PM
I believe you are going to want an 02-04 WRX tranny. It can handle the torque of the eg33. A stock forester or outback tranny from a 4 cylinder won't cut it. Axle wise there are some difference's. Also I think a 97-98 out of an RS can handle it too. An STI 6 speed would be sweet but I think there is maybe a 2 year window there that would work. Sorry I don't know this all that well. This is what I've gleaned from reading up & talking with my buddy Ian at Coldwater.
post Dec 12 2014, 04:59 PM
914-6 GT in waiting
QUOTE(JRust @ Dec 12 2014, 05:37 PM) *
I plan to use just about everything he sells so I'll give him a pm to see what he might already have in stock. thanks
post Dec 12 2014, 06:16 PM
Read thru Chris and my build threads. That's all covered including clutch info.
post Dec 12 2014, 06:20 PM
914-6 GT in waiting
QUOTE(76-914 @ Dec 12 2014, 07:16 PM) *
will do - who is chris
returf
post Dec 12 2014, 06:23 PM
Region Association: Australia and New Zealand
If you're going to develop the engine later on, I would go for the sti six speed. I've seen too many broken standard five speeds.
post Dec 12 2014, 06:39 PM
914-6 GT in waiting
QUOTE(returf @ Dec 12 2014, 07:23 PM) *
Just want 5 speed to attach to an old svx engine. budget build.
post Dec 12 2014, 08:32 PM
QUOTE(mepstein @ Dec 12 2014, 04:20 PM) *
Chris H. on here. He is the guy that responded to your earlier Suby post.
Good guy and has done the EG33 conversion. Outside of our engine choice, tranny, and hydraulic clutch, we approached the conversions from different angles. I think you should look over every ones Suby build, augment and improve our methods for the next builder. When you have that tranny on the bench listen when shifting thru the gears. Reverse makes a distinctly different sound. You'll hear it. Helps in figuring out the shift pattern. Someone posted a Suby index............Britton ????? Sheez, I forget but it's bookmarked if you need it. Although there are a few more builds since that was started there is some very good info there. Enjoy the Challenge. (IMG:style_emoticons/default/beerchug.gif)
rnellums
post Dec 12 2014, 09:04 PM
Professional Enthusiast
Pick the newest one you can find with the tallest gears. I've got an 03 2.5 RS mated to my 3.0-6 and while the acceleration in 2nd and 3rd is great, revs are pretty high on the highway for cruising.
a914622
post Dec 13 2014, 10:03 AM
I am going with the late model cable shift 6 speed. 2010 gt and up as well as a few spec B . In 12 all the 6 speed are cable shift. Much improved tranny redesigned with wider gears and able to handle the 300 tork of the Diesel engines.
Search auto-parts dot com. They run 1500-2000.
The sti trannys are bigger. Long,tall, and all the rage for the wrx guys that keep braking the 5 speeds trying to do a 4wheel burn out. So 3-4k and I'm not sure it will fit?
If your looking at the 5 speeds on the cheap almost any of the hyd clutch ones will work. Remember the 914 drops almost 1000 lbs off a wrx and with the tranny only 2wd I think the tires are going to go before the tranny.
The 5 speeds are unbalivably simple to rebuild. The bearing press it the only pain in the ass.
You want to match the clutch with the flywheel. Wrx is the same as the 911 and needs the pull style arm and slave cylinder.
Good luck. Jcl
- Lo-Fi Version Time is now: 17th March 2026 - 08:03 PM
