When this -6 engine mount was used in a conversion ..., -6 quick mt |
type47 |
Dec 15 2014, 08:58 AM
... what was the arrangement of bolts/washers/bushings/cushions/nuts/rubber isolators/silentbloc/spacers/etc was used to connect to the -4 engine mts on the body? |
GeorgeRud |
Dec 15 2014, 09:05 AM
The mount bolts directly to the front of the six cylinder engine, and the rubber isolation mounts used in pre-73 914s mount the outer attachments. It could be mounted without the isolation mounts, but that would transmit all the engine vibrations to the chassis.
type47 |
Dec 15 2014, 09:36 AM
... the rubber isolation mounts used in pre-73 914s mount the outer attachments. How about that large washer with the cut-out? Mark: (IMG:style_emoticons/default/huh.gif) I don't have a -6 motor ready to bolt in yet but was going the way of using the mount in a conversion. I used a homemade dolly to test a type IV motor https://www.youtube.com/watch?v=gRLyDnp7G_0 the quik -6 mount could be made to work w/ the dolly and move the engine around. |
Lo-Fi Version | Time is now: 21st May 2024 - 09:46 AM |
