When this -6 engine mount was used in a conversion ..., -6 quick mt |
type47 |
Dec 15 2014, 08:58 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
... what was the arrangement of bolts/washers/bushings/cushions/nuts/rubber isolators/silentbloc/spacers/etc was used to connect to the -4 engine mts on the body? |
GeorgeRud |
Dec 15 2014, 09:05 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
The mount bolts directly to the front of the six cylinder engine, and the rubber isolation mounts used in pre-73 914s mount the outer attachments. It could be mounted without the isolation mounts, but that would transmit all the engine vibrations to the chassis.
type47 |
Dec 15 2014, 09:36 AM
... the rubber isolation mounts used in pre-73 914s mount the outer attachments. How about that large washer with the cut-out? Mark: (IMG:style_emoticons/default/huh.gif) I don't have a -6 motor ready to bolt in yet but was going the way of using the mount in a conversion. I used a homemade dolly to test a type IV motor https://www.youtube.com/watch?v=gRLyDnp7G_0 the quik -6 mount could be made to work w/ the dolly and move the engine around. |
Mark Henry |
Dec 15 2014, 10:52 AM
... the rubber isolation mounts used in pre-73 914s mount the outer attachments. How about that large washer with the cut-out? Mark: (IMG:style_emoticons/default/huh.gif) I don't have a -6 motor ready to bolt in yet but was going the way of using the mount in a conversion. I used a homemade dolly to test a type IV motor https://www.youtube.com/watch?v=gRLyDnp7G_0 the quik -6 mount could be made to work w/ the dolly and move the engine around. I can't even tell you if a trans/sporto mount would work, I cut off my /4 on-body mounts. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 04:23 PM |
