Rocker Panel Rivetts, Are they available |
jack20 |
Dec 19 2014, 09:40 AM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
I want to remove my rockers, straighten and paint, then re-attach. Does any know where to buy the rivets? What about size and material? Can they be attached with a pop rivet tool?
Thanks, Jack |
r_towle |
Dec 19 2014, 01:13 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I have never seen black rivets at my hardware stores, but I made a choice to use stainless steel screws so I could remove the rockers annually.
I also put a 3/8 inch rubber washer on the bottom, in between the rocker cover and the longitudunal, with a longer stainless steel screw. The rubber spacer pulls out the bottom enough to let the dirt fall out so it wont get all clogged up around the jack post and start the rusting process all over again. Rich |
Spoke |
Dec 19 2014, 01:37 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I made a choice to use stainless steel screws so I could remove the rockers annually. (IMG:style_emoticons/default/agree.gif) Riveting the rockers on seems like a bad idea since so much damage is done to the longitudinals from trapped debris. |
Lo-Fi Version | Time is now: 13th May 2024 - 08:07 PM |
